It is currently Wed May 27, 2026 5:24 am
Post new topic Reply to topic  [ 76 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sun Jan 27, 2008 12:17 am
OK - so, are the rest of the Clallam County Fire Frequencies staying the same? I'm reworking my Clallam County stuff, and this is what I have so far from the "old" list:
154.220 County Dispatch
154.445 Joyce Dispatch
154.250 Clallam Bay Dispatch
151.925 Olympic AMB
460.100 Pt. Angeles PD
453.300 Sequim PD
453.275 Clallam Co SO
Excluding the "new" frequencies listed earlier in this thread, do the above frequencies look reasonably accurate? Are there new ones to consider (besides the ones earlier in this thread)?
Brad/N7JGX
Whidbey Island, WA
Whatever.....
PostPosted: Sun Jan 27, 2008 3:06 am
looks pretty good T68, i have a text document of all the frequencies for clallam with some jeffco an U.S.C.G as well as state corrections tossed in, if you'd like PM me an i'll e-mail it over to ya, but ur list that u have so far looks pretty good, i have afew more freqs for olympic ambulance and sheriffs dept an p.a pd, and joyce has another freq which is 153.935 (tx), but it all depends on what you want to listen to over here..better yet, PM me an i'll e-mail that doc to ya and you can pick and chose.
If Prometheus was worthy of the wrath of heaven for kindling the first fire upon earth,
how ought all the gods honor the men who make it their professional business to put it out?
~John Godfrey Saxe
PostPosted: Sun Jan 27, 2008 12:43 pm
Eric
Dont know if you got my PM. It seems to be stuck in my outbox... dont know if that means its been sent. Anyways, i wouldnt mind taking a look at that list. Could you send it my way?
bcscanner@hotmail.com
Thanks,
Cory
Cory C.
Vancouver Island Scanner Reference
http://www.members.shaw.ca/bcscanner/
PostPosted: Sun Jan 27, 2008 6:50 pm
i got your PM bc, i just sent you a copy of it, i know what you mean about your PM being in the oubox i sent 1 out to matt cawby for his list of mil frequencies an havent heard back from him, an those that requested a copy of my frequency list if you didn't get it let me know an i'll try an send it out again..
~John Godfrey Saxe
PostPosted: Mon Jan 28, 2008 8:54 am
A PM remains in the "outbox" until the recipient has read the message. Slightly different concept from email where an "outbox" is a queue between the sending client and the mail server.
PostPosted: Fri Feb 01, 2008 10:22 am
i did get the freqs, but between prepping to teach, and teaching CERT/MYN classes and shoveling my driveway, i hadn't time to respond; i do appreciate the data.
bob :D
PostPosted: Wed Feb 06, 2008 10:09 am
Eric wrote:
they will be switching and adding frequencies, they should be up by early part of next year, but here is what i have so far
154.1750 Clallam County Fire Dist 3 ( Old Primary / Tac 2 )
151.7750 Clallam County Fire Dist 3
153.7850 Clallam County Fire Dist 3 ( Tac 1 )
154.0100 Clallam County Fire dist 3 ( Primary TX )
154.0325 Clallam County Fire Dist 3 ( Tac 3 RX )
154.3850 Clallam County Fire Dist 3 ( Tac 5 )
154.0335 Clallam County Fire Dist 3 ( Tac 3 TX )
155.7825 Clallam County Fire Dist 3 ( Primary RX )
eric...I'm curious as to where you got the information about this. The only accurate frequency and for what it will be used is the CCFD3 New Primary TX/RX. Some of the other frequencies are correct, but not assigned at this time.
PostPosted: Wed Feb 06, 2008 10:46 pm
that is what i thought i heard, and i took it as the '' gospel truth '' so i stand corrected, going back through my scanner list and the fcc data base i need to correct 154.385 i have it listed as CCFD3 tac it is not even licensed to them that i can find, it is how ever licensed to san juan fire with output power of 5 watts (to me that is a tac freq) & other agencys the only 1 that is licensed to CCFD3 that even has 5 watts is 151.775 <----tac ch??? the other freqs have 50 watts with the exception of 155.7825 that has about 100 watts, so i should be correct on that one as the primary, but shouldn't 154.0100 have the same wattage if it is supposed to be another primary ch?? , cause 154.175 has the same wattage for both fixed base and mobile if you can clear up this list radiojoe i know i and some other folks on here would appreciate it.
~John Godfrey Saxe
PostPosted: Thu Feb 07, 2008 7:49 am
I have not been authorized to give out any information until the project is complete. If the people of this board would like information, they can go to the FCC ULS website like you did and get your information there, and make assumptions as to what it will be used for. Unfortunately at this time, not even I know what all of the other frequencies are going to be used for.
PostPosted: Thu Feb 07, 2008 4:44 pm
The part that confuses me when checking the FCC database, is it lists the frequency 154.0325 as associated with 155.7825 (repeater output). But it is actually 154.0100 which is being used as the input.
Cory C.
PostPosted: Thu Feb 07, 2008 8:42 pm
Obtaining frequencies is a game of seek and find. You can start the process of obtaining frequencies and a couple of years later finally have the license in hand. By then you may have found other better choices that have since become available. The associated frequencies on any license are not necessarily used as a pair or on the same system. Just look at the State Patrol licenses.
Due to this "game" of "Find Your Frequency", other frequencies that were acquired may or may not ever be used. They should eventually be returned to the "pool" if they are not used.
The channel list for CCFD#3 is not complete. The decisions of channel use have not yet been made although it looks as if the Primary system pair will probably stay. But there is no guarantee.
There are always potential interference issues to look and test for.
Hope that helps! :mrgreen:
PostPosted: Fri Feb 08, 2008 7:27 am
Yes, thank you. I wasnt sure how the licensing thing was done, whether all the info in the FCC database was concrete, or if it was more as how you said. Now I know.
Cory C.
PostPosted: Fri Apr 11, 2008 8:09 pm
It looks like next tuesday April 15th, Clallam Fire 3 (Sequim) Will be switching from our Simplex system to a Repeated/Voted over IP System around 1900 hrs. We will be looking for input from you folks in scanner land on if you notice any anomolys.
Repeater Input: 154.0100 with a PL 123.0
Repeater Output: 155.7825 with a PL of 123.0
We have 3 repeaters, one is located at Clallam Fire 3 Head Quarters in Sequim, one at the WSP Detachment in Port Angeles, and one in Cape George near Port Townsend.
Please feel free to use this board as a discussion of any issues and one of our radio techs along with myself will be checking it regularly.
Thanks!
Joe 8)
PostPosted: Sat Apr 12, 2008 6:05 am
interesting. 1900 is when we do the county ARES net, including a Sequim simplex net from the station, might be crowded in the ECC! i presume that black box on the west wall of the ECC has something to do with the new system.
bob
ke7hzb
PostPosted: Sat Apr 12, 2008 10:25 am
That new box in there is actually a replacement radio for our current simplex system. We will be continuing to utilize our current frequency as a tac frequency. We decided that it would be beneficial to have a new radio in case we needed to switch back to simplex if there were problems that came up with the repeated system. There won't be anyone in the radio room though, you probably won't even notice anyone except for myself and a few others when we are reprogramming pagers for the whole district. :lol:
