It is currently Sat May 16, 2026 10:49 pm
 Post subject: PRO 2096
PostPosted: Wed Sep 15, 2010 5:16 pm
The ribbion connector for the LCD, how is it connected on the other end? Anyone have pics of the inside?
Well got the scanner don't know if it can be fixed. The guy tried to fix the ribbion cable buy removing it and soldering a crap load of wires to replace it. Didn't work he said. A shame but I only have $42 in it and also got a programming cable(20-047) & driver disc with it, now I have two. I'll order a new ribbion cable and see if I can make it work. If not it will make a good parts radio. It looks like brand new.
Date code looks like 2007 year.
 Post subject: Re: PRO 2096
PostPosted: Wed Sep 15, 2010 5:30 pm
yikes, I wonder if one could of just reset it as it has a connector like a mini-molusk or at least cleaned it up a bit. Maybe the two ends of the cable have a connector with a RS replacement
PostPosted: Thu Sep 16, 2010 6:11 am
The inside looks the same as the pro2050, with a few different parts of course. The other end was soldered to the front board, I counted 22 solder points. I think if I can get a new ribbon cable, clean up what he did and can fix(if I can) where the traces pulled off it just might come back to life.Where the ribbon plugs in that connector is still there. IfI can't fix it a lot of parts can be used on the pro2050.
PostPosted: Tue Oct 19, 2010 5:18 pm
I don't know how similar the 2096 is to the 97, but this might help:
http://www.interceptradio.com/wiki/inde ... Replacment
PostPosted: Tue Oct 19, 2010 5:22 pm
Hey I think someone said that was on another board :bowrofl:
PostPosted: Tue Oct 19, 2010 5:30 pm
It got copied over there without the original author's permission.
PostPosted: Tue Oct 19, 2010 6:00 pm
I thought so. :roll:
