It is currently Fri Feb 27, 2026 5:23 am
 Post subject: Can someone help me out
PostPosted: Sun Jun 05, 2005 9:39 am
I work in a new casino in Lakewood. I want to see what our radio's come up freq wise. Now I'm a novice with scanners. How would I check to see where it comes up?
 Post subject:
PostPosted: Sun Jun 05, 2005 11:16 am
Are there any letters on the antenna indicating 'UHF or VHF'?
Pop the battery off and look and see if any indication of uhf or vhf.
Here's an example of what I would do:
See if there is any license paperwork floating around the office, sometimes the freq is listed. If not, say it's UHF. Look around in the business band allocations, from 461.00 to about 464.000. It may take some time, do it when you know there is high radio traffic.
Also check the FCC web site for the business name, check the parent company too.
Good luck.
 Post subject:
PostPosted: Sun Jun 05, 2005 11:24 am
Post the name and one of us can look up what the FCC has.
Get a hold of a frequency meter that gives you the freq when you hit the transmit button of the radio.
-good luck
-m
 Post subject:
PostPosted: Sun Jun 05, 2005 11:33 am
All the ones I've seen down here are UHF.
 Post subject:
PostPosted: Sun Jun 05, 2005 12:12 pm
From back of radio
FCC ID ALH36423110
TK 3160 450-490 Mhz
Don't think we registered with the FCC but the place is Happy Days Casino, owned by Charles McSwain. Not sure if that helps.
I tried scanning those mhz and talking on the radio with no result.
 Post subject:
PostPosted: Sun Jun 05, 2005 2:39 pm
Right, nothing at the FCC for either name.
 Post subject:
PostPosted: Sun Jun 05, 2005 4:20 pm
welcome also try checking the back of the radio sometimes they will print the freqs on the back !
GOOD LUCK
STEVE F.
GOD BLESS 73s
 Post subject:
PostPosted: Sun Jun 05, 2005 8:09 pm
:D We need to know the Model Number. Take the battery pack off and look for a Model Number. NOT a serial number. Then we can tell you what band.
 Post subject:
PostPosted: Sun Jun 05, 2005 10:47 pm
TK 3160 450-490 Mhz
 Post subject:
PostPosted: Mon Jun 06, 2005 2:52 am
:D :D You will have to try searching the "business" UHF frequencies. You will have to set your search limits for the following "Sub-Bands" from 451.00 to 453.0375, 454.00 to 455.00, 456.00 to 458.0375, 459.00 to 460.00, from 460.65 to 465.00 and 465.65 to 470.00. The radio may be able to use the UHF T band channels above 470 Mhz. However - those frequencies are NOT allowed to be used in Washington State. Only after searching all of the other UHF Sub-bands would I try to search above 470 Mhz. I would start with 460.65 to 465.00 and then 465.65 to 470.0 Mhz. Its better than 70 % that you will locate the frequencies within one of those 2 "Sub-bands". The 454.00 to 455.00 and 459.00 to 460.00 Mhz sub-bands are for RCC - Radio Common Carrier -- Private Radio Telephone companies. However -- several RCC firms "rent out" those frequencies. Check there last. And let us know what you locate. Keep the portable at least ten feet from the scanner while transmitting. It will overload the receiver and JAM the scanner and give a false readout.
 Post subject:
PostPosted: Mon Jun 06, 2005 10:38 am
Thanks guys, will give that a shot and let you know!
 Post subject:
PostPosted: Mon Jun 06, 2005 1:19 pm
If you have a Close Call scanner like the Uniden 246T Scanner you could put it in the close call mode. Then key up the radio and see what the freqs are and pl or dpl tones are.
Good luck
Michael R.
AD7TH
 Post subject:
PostPosted: Mon Jun 06, 2005 1:24 pm
Radio Shack Pro 62, oldie but still works well :)
 Post subject:
PostPosted: Sat Jun 11, 2005 7:52 pm
since the radio is in UHF and there are no FCC licenses under the casino name then you could be using FRS frequencies or the casino is licensed under a corporate name. Is the casino privately owned or by a corporation?
 Post subject:
PostPosted: Sat Jun 11, 2005 8:30 pm
Privately owned but think he's "incorporated". I did find out we have scramblers on our radios, so that maybe why its not working.
