It is currently Sat May 09, 2026 4:59 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Oct 15, 2012 12:04 pm
KB7AIL wrote:
Haven't they been talking about a radio like this for over a year and not bringing it to market?
The KG-UV920R has nearly identical specs, came out already, and flopped pretty bad due to poor performance.
Any surprise?
Proof yet again that one "gets what they pay for"...
PostPosted: Sat Nov 10, 2012 11:49 pm
I first made this post in September 2012. I appreciate all of the responses. I have heard the radio is in the USA and is being tested by a dealer or dealers. I believe it was Atomic Taco who referenced a previous entry in the US market by a Chinese company and apparently the preformance was pretty dismal. Has anyone seen test reports or seen actual reviews of this radio?
I have also read some good reports on this particular importer/dealer. Has anyone here done business with this company-Import Communications?
Many thanks,
Wayne
KF7FYL
PostPosted: Sun Nov 11, 2012 12:05 am
Gampawayne wrote:
Atomic Taco referenced a previous entry in the US market by a Chinese company and apparently the preformance was pretty dismal.
Same manufacturer. Although I think they might be releasing a new version. See next.
It's not shipping yet; one person has a preproduction model: http://va3isp.com/
PostPosted: Mon Nov 19, 2012 6:00 pm
Taking preorders now:
http://www.wouxun.us/item.php?item_id=2 ... gory_id=64
PostPosted: Mon Nov 19, 2012 10:11 pm
Dang that's tempting
PostPosted: Mon Nov 19, 2012 10:23 pm
Hard to believe a radio like this is part 90
PostPosted: Mon Nov 19, 2012 10:28 pm
Kinda scary huh?
PostPosted: Mon Nov 19, 2012 10:48 pm
It hasn't made it through yet, if it ever does.
PostPosted: Tue Nov 20, 2012 8:44 am
You can't get FCC type acceptance on a user field programmable radio.
PostPosted: Tue Nov 20, 2012 2:20 pm
You CAN as long as the option is "restricted"
PostPosted: Tue Nov 20, 2012 3:04 pm
According to this it is (See last line) :D
Features added for final-production radios:
Updated Microphone -- Added a built-in speaker in mic's front & a switch to defeat the Channel Up/Down button (which was easy to accidently hit). This switch was also supposed to lock all buttons on the mic, but not sure about that yet.
Bracket for mounting detachable control head.
Updated Firmware -- Several menu functions have been added. See the owner's manual for all functions.
FCC Part 90 Certified -- ID # T4K-5888UV
Features:
Receive Range (FM) 134-174, 200-260, 350-400, 400-520 MHz & FM Broadcast
(AM) 118-134 MHz (Air Band)
Transmit Range (FM) 134-174, 400-490 MHz
Output Power 50, 35, 10 & 5 Watts
Bandwidth Wide (25 kHz) & Medium (20 kHz) & Narrow (12.5 kHz)
Tuning Step 2.5, 5, 6.25, 10, 12.5, 15, 20, 25 & 50 kHz
True Dual Receive - receive two signals at the same time -- second side can be muted while transmitting
Separate Tuning Knob and Volume Control, each side
Separate Function Buttons, each side
Either side can be VHF or UHF at any time - VU, UV, UU, VV - One side can be VFO and the other side Memory at the same time
Cross-Band Repeat (that works!)
Alphanumeric Display
4 x 256 Memory Channels
CTCSS, DCS, DTMF, ANI, PTT ID, 2Tone/5Tone Encode & Decode
Scrambler Included
DTMF Microphone
Detachable Control Head (CAT5 separation cable)
Computer Programmable
FCC Part 90 Certified (T4K-5888UV)
PostPosted: Tue Nov 20, 2012 4:39 pm
:bowrofl:
When I enter my Motorola XPR series portable I get-
When I enter the Anytone provided FCC number I get-
Looks like someone is getting creative.
PostPosted: Tue Nov 20, 2012 4:47 pm
If we knew the Form 731 confirmation number, we could check pending.
PostPosted: Tue Nov 20, 2012 5:25 pm
https://apps.fcc.gov/oetcf/eas/reports/ ... Search.cfm Just enter "t4k"
Ive found some of their other products here.
But in their own docs...
FCC ID: T4K5188U1 Attestation statement that the end user can’t tune the transmitter.
Gentlemen;
The equipment meets the requirements of the FCC Rules, Part 90.203(e) and (g), as applicable.
Programming of this product’s transmit frequencies can be performed ONLY by the manufacturer or by
service or maintenance personal. The operator cannot be program transmit frequencies using the
equipment’s external operation controls.
Qixiang
https://apps.fcc.gov/eas/GetApplication ... ?id=965538
https://apps.fcc.gov/eas/GetApplication ... ?id=963676
This is pretty entertaining. Ive never seen one of these that couldn't be programmed in the commercial bands by the user. Apparently modded by the distributor.
PostPosted: Wed Nov 21, 2012 7:33 am
I have the KG-UV6D handheld, which has similar type-accepted / locked-out VFO capability. You have to run a one-time routine to unlock the VFO, then it all works as advertised.
