It is currently Tue May 26, 2026 10:42 pm
 Post subject: Auburn PD gone?
PostPosted: Tue May 20, 2008 2:45 pm
They used to be on 36944. Now it's silent. Doesn't come up on any of my scanners; I'm using 851.8125. Tried it with status bit ignore on and off.
 Post subject: Re: Auburn PD gone?
PostPosted: Tue May 20, 2008 3:54 pm
Try 36848. It's Algona/Pacific PD. They alternate patching that talkgroup to Auburn and vice versa. Depending on which way it's patched, it'll show up differently in your scanner.
PostPosted: Tue May 20, 2008 4:12 pm
If only it was that easy to get rid of them......
PostPosted: Tue May 20, 2008 5:07 pm
Thanks B, that worked.
PostPosted: Thu May 22, 2008 11:07 pm
I don't know what scanner you have but, if it will let you, try 36947. When they patch their primary with Pac/Alg... their TGID goes up by 3. My Pro 97 won't let me put that TGID in but my BCT15 will!
PostPosted: Thu May 22, 2008 11:33 pm
I hear 'em on 36944 on my 97, and 36947 on my BR330. Or if I choose to ignore the status bit, I can put 36944 in.
PostPosted: Thu May 22, 2008 11:47 pm
Maybe I'll set the status bit to "Ignore" on my BCT15 and try that out for awhile.
PostPosted: Thu May 22, 2008 11:51 pm
That function isn't not documented very well anywhere. I'm using bcTool, and I have the "Status Bit" box checked. I just looked in the manual and here's what it says:
Ignore - the scanner rounds all received ID's down to the next interval of 16.
Yes - the scanner treats all received ID's as unique ID's.
PostPosted: Fri May 23, 2008 12:37 am
I probably read that in the manual when I got my scanner but I had kind of forgot about the setting until you mentioned it. I had it set to "on". But with that info, I changed it to "ignore" and that sounds like a better way to go! Keeps from having to enter multiple TGID's because they turn on and off different patch set-ups.
Thanks...
Chuck
