It is currently Mon May 11, 2026 10:22 pm
 Post subject: 150Mhz Tuned Antenna
PostPosted: Fri Oct 07, 2011 12:50 pm
Looking for suggestions for an inexpensive 150Mhz tuned mobile antenna with BNC connection.
Searching for something better to use with my PDW setup.
Thanks...
 Post subject: Re: 150Mhz Tuned Antenna
PostPosted: Fri Oct 07, 2011 2:06 pm
Why not just get a tuned 1/4 wave whip NMO with the proper mount. Cost would be around $25-30 total...
PostPosted: Fri Oct 07, 2011 3:21 pm
5540 divided by 150 divided by 2 is the size of your 1/4 wave whip. 18.46 inches
PostPosted: Fri Oct 07, 2011 3:36 pm
Yup. Price is good too: http://www.wpsantennas.com/qwb144-anten ... black.aspx
PostPosted: Sat Oct 08, 2011 10:25 am
Sorry, I was not clear. I meant my mobile handheld.
I'm assuming those antennas need a decent ground plain to work properly?
PostPosted: Sat Oct 08, 2011 11:13 am
In that case you have loads of options. Larsen, Maldol...
PostPosted: Sat Oct 08, 2011 11:30 am
Yep!
If you have groundplane issues a Laird (or equivalent) 1442N is a good choice. I use em on my slicktops on the side fender to help hide em due to them being a tad shorter than a 5/8 gain 1443. They work very well with or without groundplane...
PostPosted: Sat Oct 08, 2011 11:31 am
Here you:
http://www.wpsantennas.com/v150bn-anten ... tenna.aspx
http://www.wpsantennas.com/ts150bn-ante ... tenna.aspx
http://www.wpsantennas.com/exb150bnx-an ... tenna.aspx
PostPosted: Sun Oct 09, 2011 7:30 am
Thanks for the links.
PostPosted: Tue Oct 11, 2011 4:50 pm
I've had good results with a 5/8th wave from Smiley: http://www.smileyantenna.com/product_in ... ucts_id=29
