It is currently Wed May 13, 2026 2:25 am
PostPosted: Tue Aug 02, 2011 11:00 am
Going through and checking the stuff I have programmed for Paine Field Tower. I have a question on a couple of notes associated with the listed Frequencies.
109.3 - PAINE FIELD ILS/DME RWY 16R
110.6 - PAINE FIELD VOR/DME PAE
114.2 - PAINE FIELD VOR PAE
So what is ILS, VOR and DME mean?
PostPosted: Tue Aug 02, 2011 11:11 am
ILS: Instrument Landing System. This is the glideslope and localizer that provides guidance down to the runway threshold.
VOR: VHF Omnidirectional Radio range. A system of fixed directional beacons, sometimes at an airport, sometimes freestanding.
DME: Distance Measuring Equipment. Often co-located with a VOR, allows you to figure the distance from a beacon, as well as a heading, giving you a reasonably precise location.
PostPosted: Tue Aug 02, 2011 11:24 am
Ahh ok. So this is nothing that will have voice communications on it, correct?
And I'm assuming that holds true for ATIS frequency too?
Thx for the help.
PostPosted: Tue Aug 02, 2011 11:46 am
Correct.
ATIS is a recorded loop of current airport information. So it's voice, but not "live".
PostPosted: Tue Aug 02, 2011 11:50 am
Got it. Thanks a bunch for the help..
PostPosted: Tue Aug 02, 2011 12:08 pm
Here is what I have programmed. Does it look to be correct?
Paine Tower 120.20000
Paine Tower 121.30000
Paine Tower 132.95000
Paine Ground 121.80000
Approach/Depart 128.50000
Boeing Everett 123.47500
Clearance 126.75000
PostPosted: Wed Aug 03, 2011 7:02 am
http://www.airnav.com/airport/KPAE
On the right, under 'airport diagram', select the link to download the .PDF (official FAA published) version.
Airnav will have the comm frequencies for all public airports in the US.
PostPosted: Wed Aug 03, 2011 7:12 am
Thanks for that .pdf link.
Ok, my last question I think. I noticed that there are two different frequencies published for Tower and Ground control.
Both East and West have their own frequency, but also have a common frequency listed of 256.7. Are the two different tower frequencies simulcast on 256.7?
