It is currently Fri May 15, 2026 10:30 am
PostPosted: Wed Mar 25, 2009 9:07 pm
Hi, im in the Bellingham area and have a very old scanner that sounds like it has a short or something in the squelch button maybe. Anybody know of anyone that works on scanners, and contact info for them? thanks!
PostPosted: Thu Mar 26, 2009 5:51 am
I have used G&G in New York for years. They do an EXCELLENT job and very reasonable. I've attached their link.
http://www.iinc.com/ggcomm/
Spectrum Communications, Inc.
526 S Locust Lane
Moses Lake, WA 98837
http://www.scml.us
http://www.insp.com
PostPosted: Thu Mar 26, 2009 5:59 pm
Is it just a dirty contact, or a bad solder joint? What kind of unit is it? The Regency's had some units with a slide control on it, and they get dirty very easy. If it's just a dirty contact, try some tuner cleaner. You should be able to get some at Fry's, I doubt that a radio shack would still sell it.
You also might want to check with your LOCAL (not Sears, or other big names) TV repair shop.
Jim
