Crank Radios
Revision as of 19:01, 23 October 2011 by Rich (Talk | contribs)
The early models on the market had a spiral spring-steel "clock spring" that you would wind up and in turn would power a generator, thus generating your power dynamically. The newer models have you crank the generator to charge batteries and/or power the radio. The only drawback to this design is the radio runtime can be severely limited when the batteries have problems holding a charge. In fact many people get shipped older inventory with bad batteries right out of the box ! Due to this issue I prefer a radio with replaceable batteries and/or a generator big enough to directly power the radio without a battery present. Its a shame some of these radios come with bad batteries. One mod I recommend is installing high quality Low Self Discharge NiMH batteries.
Kaito (all models)
Midland
C Crane
Eton (most models)
Sangean MMR-77
Freeplay Eyemax WB 2009
By far the best of them all. Super beefy crank/generator and the solar cell actually performs. More rugged/durable construction compared to the others. Has 3 internal 600mAH AAA NiMH cells. Costs a little more ($45) but well worth it. As with the Sangean, the generator is brushless. If you look at the photos to the right you'll see the generator is much bigger than the Sangean.
