Crank Radios
Kaito (all models)
Midland
C Crane
Eton (most models)
Sangean MMR-77
Good radio but is only AM/FM (no NOAA weather radio). Can run off 2 internal AAA NiMH or 2 replaceable AA cells. Its built-in light is incandescent and draws a lot of current (why didn't they use a LED?). The crank will charge the internal batteries but not the replaceable ones. I was able to modify mine by replacing the incandescent light with a 5mm LED and rewired the battery circuit such that the crank will charge the replaceable batteries. After these mods I'm quite happy with the product. The generator is brushless. I replaced the incandescent light with a LED.
