Crank Radios
Revision as of 18:40, 23 October 2011 by Atomic taco (Talk | contribs)
Currently there are a number of wind-up crank radios available from numerous vendors. These radios are usually marketed as "emergency" radios rather than alternative powered radios. These radios are popular in hurricane/tornado prone areas because they can be stored away for long periods without the user having to worry about keeping fresh batteries in them. Most of these radios include NOAA weather reception which tends to be more reliable/informative during weather related disasters.
Kaito (all models)
Midland
C Crane
Eton (most models)
Sangean MMR-77
Good radio but is only AM/FM (no NOAA weather radio). Can run off 2 internal AAA NiMH or 2 replaceable AA cells. Its built-in light is incandescent and draws a lot of current (why didn't they use a LED?). The crank will charge the internal batteries but not the replaceable ones. I was able to modify mine by replacing the incandescent light with a 5mm LED and rewired the battery circuit such that the crank will charge the replaceable batteries. After these mods I'm quite happy with the product. The generator is brushless. I replaced the incandescent light with a LED.
Freeplay Eyemax WB 2009
By far the best of them all. Super beefy crank/generator and the solar cell actually performs. More rugged/durable construction compared to the others. Has 3 internal AAA NiMH cells. Costs a little more ($45) but well worth it. As with the Sangean, the generator is brushless. If you look at the photos to the right you'll see the generator is much bigger than the Sangean.
