Revision as of 17:30, 8 October 2011 by Rich (Talk | contribs)
I was prompted to write this article after working on a cutover with an email provider. Despite my TTL being set to 60 seconds for days, their engineer was insistent that we had to "wait for the DNS changes to propagate" before the mail server would function properly and that it "could take up to a day before the propagation was complete". Even worse, he claimed his team of 20 engineers believed the same thing.
Now repeat the following until you remember it: Caching servers (resolvers) pull the data from the authoritative server. The authoritative server does not push (propagate) the data. "Propagation" is a term used by people who don't understand the correct usage of TTL.
Besides a DNS name and IP address, clients and caching servers also cache a value called "TTL" or "Time to Live". This value represents the number of seconds that the information is valid for. Once the time has expired, a client or caching server is required to ask your DNS server for new information. Historically the default TTL has been 86400 seconds (one day). In this scenario it can take up to a day for the internet to see your DNS changes if you don't adjust TTL first. The correct way to administrate DNS is to set the TTL and negative cache setting to a low value (for example 300 seconds) at least a day prior to your DNS change (or longer if your default TTL is greater than 86400). Doing it this way allows sufficient time for all the clients/resolvers to honor your new 300 second TTL. Now your DNS changes will be recognized in 5 minutes or less. Of course you can use lower values (like 60 seconds) if needed. Remember to increment your zone serial number when reducing your TTL. This is a frequently overlooked step.
Proper usage of TTL can make cutovers nearly instantaneous. Keep in mind that some socket based applications may do a DNS lookup (gethostbyname) only once and may need to be reset. A properly written program will always perform a gethostbyname prior to each time it opens a socket (except when it has a cached list from a previous round-robin DNS reply).
