- Besides a DNS name and IP address, clients and caching servers also cache a value called "TTL" or "Time to Live". This value represents the number of seconds that the information is valid for. Once the time has expired, a client or caching server is required to ask your DNS server for new information. Historically the default TTL has been 86400 seconds (one day). In this scenario it can take up to a day for the internet to see your DNS change. The correct way to administrate DNS is to set the TTL and negative cache setting to a low value (for example 300 seconds) at least a day prior to your DNS change (or longer if your default TTL is greater than 86400). Doing it this way allows sufficient time for all the clients/resolvers to honor your new 300 second TTL. Now your DNS changes will be recognized in 5 minutes or less. Of course you can use lower values (like 60 seconds) if needed. Remember to increment your zone serial number when reducing your TTL. This is a frequently overlooked step.
