Revision as of 22:50, 9 July 2011 by Rich (Talk | contribs)
Each battery pack is made of (4) 40160S LiFePO4 batteries with a battery management circuit put into a Huggies wipe box. The battery management circuit sits on top of a plastic board which is an Akro-Mils 40150 (3.3 x 7.7 x 0.1 inch). Mount the batteries in the plastic holders, wire them in series with the bus bars, mount the battery management circuit, then wire it in. I recommend using a 30 amp fuse as pictured. Once this is done attach a 30A (12-14AWG) Powerpole connector with 12-gauge wire. The battery management circuit will charge the battery up to 14.2v before it automatically cuts off. The charger should be at least 14.6v.
