To make the coil, glue 4 pieces of .065 Nylon Edge Trim as shown in the photo (credit to Phil AD5X for finding this edge trim). When cutting them to length, remember to offset each one to correctly accomodate a spirally-wound coil. Once this is done, drill a .065" diagonal hole from the edge of the cap through the top of each cap (see photo), thread the wire through the hole and wind the coil with .064" (14AWG) tin coated copper wire. Remember to keep tension on the coil or else it will wind loosely. The wire is stiff and doesn't come off the coil perfectly so there will be some manual coil alignment/straightening to do after the coil is wound. Once the coil is wound, put the ends thorough the 16-14AWG 3/8 ring terminals, then cut & solder. Be careful of heat damage to the plastic while soldering. Its usually best to loosen the end nuts prior to soldering as it will conduct less heat away from the ring terminals.
The monopod needs to be shortened to fit into the pack. Going around the perimeter of the small end rod, cut off the bottom half of the top rubber cap. This will allow the rod to collapse about an additional 1/2 inch. The bottom cap can be removed by pushing in the two roll pins with a small center punch. Then, with the rod fully collapsed, you will see there is about a 1/2 inch you can saw off the big end without hitting the smaller rods that collapse inside of it.
