Revision as of 15:27, 22 June 2011 by Rich (Talk | contribs)
FM/SSB/CW/packet
The antenna mount uses 1/4-20 hardware. I recommend replacing two of the nuts with wingnuts. Cut a piece of Belden 8219 RG58A/U
