Now we take a piece of 1/4 inch schedule 80 pvc pipe and drill/tap it for 3/8-24 threads the same way you did the aluminum rods (except please don't use lubricating oil). The pipe should be about 7 1/2 inches long and later you might have to make some slight length adjustments for fit. Once your threads are tapped you can thread a 1.5 inch 3/8-24 stud into each end then put a 3/8" USS Flat Washer over the end (see photo below). Put one end into an end cap, put a 3/8" USS Flat Washer on the outside of the end cap, stack one 16-14AWG 3/8 ring terminal on top of the washer, and secure it with a 3/8-24 x 1-1/8 Hex Coupling Nut stacked on top of the ring terminal.
