Revision as of 23:56, 21 June 2011 by Rich (Talk | contribs)
FM/SSB/CW/packet
For a horizontal option I built a tapped voltage balun which connects to two spools of wire. These wire spools can also be used as a counterpoise for vertical configurations.
