Uniden GPS Setup
Uniden Scanner GPS Setup
On the other side of the null modem adapter is a GPS adapter cable. The left side of the adapter cable is connected to the GPS and the right side is connected to the power source. See the white cable on the right side ? The GPS adapter cable originally had a round male plug on this end. We cut off the plug and connected the red and black wires to a USB printer cable (the white cable). We then connected the USB plug to a 12 volt USB adapter. This was done because the GPS requires 5 volts to operate.
Null modem adapter: StarTech NM9MM ($8 at Amazon)
You can save $18 by skipping the adapter cable and buying your own 9-pin connector.
