Revision as of 18:12, 26 July 2025 by Rich (Talk | contribs)
Modern 10W HF/50mhz all mode portable transceiver with a rugged aluminum case.
Made in Russia. Worth checking out. Current price $790.
10W HF/6/2/440 all mode portable SDR transceiver with a touchscreen display.
Matching pack and radio-specific ATU available.
If I had to re-do this project today this radio would be under serious consideration despite being 10W.
Current price $1300.
2025 Update: Go buy a Bioenno Power 12v 20Ah battery pack. It weighs 5 pounds 1 ounce. The original pack I built (described below) was 16Ah and weighed 5 pounds 0 ounces.
Update November 2023: While this article is still a good read for building your own pack, it is probably easier to buy a Bioenno Power BLF-1215A LiFePO4 pack (15Ah / 4.5 lbs). Current price is $210.
