Mount Rainier National Park
Revision as of 22:43, 18 September 2014 by Forest3433 (Talk | contribs)
Frequencies
169.7250Main Park/LE
163.7125Common 2
168.6125Common 1
163.0650
169.9000USFS F1
156.1350OSCCR (203.5)
159.0900Buckley Fire (Dispatched by Fife PD), Medic 35 often closes ALS unit (AMR unit with AMR Paramedic and Buckley Fire EMT on board)
Dispatch Park Comm Center located at Tahoma Woods
Enumclaw Enumclaw Police Dispatch used in evening and some holidays for "LE units" (Law Enforcment)
Unit 100 Park Superintent
Most 7** Units are Park LE
Forest 55USFS LE (Dispatched by Bellevue WSP)
Aid 4031 or Aid 89NPS Aid Unit (Paradise)
Aid 4032 NPS Aid Unit (White River)
Radio Terms
Radio Channels
Channel Name  Area Covered
Paradise Nisqually Entrance to Paradise. Longmire, Upper Stevens Canyon Rd.
TWoods Longmire to Eatonville.
Gobblers Nisqually Entrance to Tahoma Woods, Southwest backcountry
Packwood Skate Creek Rd., Packwood, Box Canyon to Backbone Ridge on Stevens Canyon Rd.
Shriner Ohanapecosh to Cayuse Pass, Chinook Pass, Sunrise, Lower Stevens Canyon Rd.
Crystal Cayuse Pass to Enumclaw, White River, Sunrise Road, Northeast backcountry
Sunrise Sunrise area
Fremont North backcountry, areas above Sunrise
Tolmie Carbon River, Mowich Lake, Eatonville, Enumclaw, Northwest backcountry
West Direct Local-area use, Westside ranger district
East Direct Local-area use, Eastside ranger district
