-  Battery, AC, or solar
I ended up going with the Z11pro2 as it can autotune based on RF sense which keeps the CAT and ACC ports free.  This is good because we
need both ports for our data interface.  Another bonus of RF sense tuning is it makes the radio PC-ALE capable provided the antenna is
I initially considered using 11 Accupower NiMH low-discharge "D" cells  (10aH, 1.25v, 145g ea.)
batteries however I opted to build two battery packs.  4 of these batteries in series gives you around 13 volts.
If you intend on taking your backpack radio on a commercial aircraft, keep in mind there are restrictions on high capacity lithium ion batteries.  If you believe this will be a problem you can build a pack from 11 NiMH D cells or use a pre-made NiMH RC pack.
for about $14 off ebay.  It is relatively small and weighs 0.4 lb. I run it through a bridge rectifier which reduces the voltage to 14.8V which is suitable for operating the radio and charging the battery pack. Of course running DC through a bridge rectifier only uses two of the four diodes however it was an inexpensive solution which is much easier than standalone diodes to mount to the cable/fuse.
I found that the battery pack can draw up to 8A during charging so I used a 10A fuse on the power supply. Yes, I know the power supply is only rated at 7.5A and putting a 10A fuse on it is not good practice. So far it hasn't been a problem. During charging the bridge rectifier can get quite hot so make sure it is on a non-flammable surface.  The obvious solution to all this would be a series current limiting resistor which is something I'll look into when I get the time.
PowerFilm F15-1200 20W    (10.5 x 6.5 x 0.6"   1 lb )
Nice compact and light panel but a little pricey at $10/watt.  I would have gone with their 30W panel but it was even more overpriced.
EEEPC 1000h.  Small battery-efficient netbook with 10" screen.  Used it because I had it on hand.  Any netbook would probably do ok so
of others). It was difficult to find anything that would collapse to under 18 inches (requirement for the pack I'm using).  It was probably just as well
My original intent was to buy a "Buddi" product and evaluate how it worked in a vertical configuration. The only issue was whether their 80 meter coil would fit in the pack. I emailed them multiple times asking the dimensions of the coil but unfortunately all of my emails were ignored.  This probably speaks volumes as to how they handle issues after a sale so I thought it best not to do business with them until their customer communication improves.
I looked at dozens of packs before settling on the Jansport Driver 8.  Most other packs were either oversized and/or too heavy.
walking around with the pack on your back.  It also works great for fixed operations as the pack itself can be used as an antenna base.
The wheels are inline skate wheels and have a very low ground clearance. It will roll fine inside buildings or on a paved sidewalk. The wheels will not work on a trail. This is unfortunate as it is much easier to pull 35 lbs on wheels than to heft it on your back.  One possible solution to this is to run a 1/2 inch rod (or thread stock?) along the bottom of the pack and install a pair of 10" x 1.75 lightweight plastic wheels.  I would use Martin Wheel part number 110 wheels because they come with metal ball bearings.
To make the aluminum extension rods you need a 3 foot piece of aluminum rod.  Cut the rod into 3 pieces, 2 of them will be 17 inches long and the third piece will be the remaining 2 inches.
Now grab the remaining 2 inch piece of aluminum rod. Drill one end 1 inch deep with a size F (.2443 inch) bit then drill the other end 1 inch deep with the 21/64 inch drill bit you used for the other rods.  Tap 5/16-18 threads into the size F end and 3/8-24 threads into the 21/64 end.
The antenna mount uses 1/4-20 hardware. I recommend replacing two of the nuts with wingnuts.  Cut an 11 foot piece of Belden 8219 RG58A/U and loop it twice through two Laird LFB187102 ferrites as shown in the photo below. The coax fits tightly and we do not want to stretch it while pulling it through the ferrites so use a non-petroleum lubricant (I used cooking spray). Once this is done you can put UG-175/U reducers on the cable and solder a PL259 connector on each end.
The antenna wire is spooled on a (2) Coleman 827E140T colthesline reels (thanks to Richard WA6KYR for finding these).  Each Coleman reel comes with 21 feet of nylon cord. Pull all the cord out and cut off 13 feet so there is 8 feet remaining on the spool. Attach 59 1/2 feet of 22AWG insulated hookup wire to the end of the nylon cord. You can do this by stripping the end of the wire and pushing it through the middle of the nylon cord about 1/2 inch from the end, then secure the end of the nylon cord by lightly melting it with a lighter or soldering iron. Now you can reel in the wire. If it gets stuck you can open the reel with a 1/3 turn of the enclosure shell. Attach a 16-14AWG 3/8 ring terminal to the end of the wire.
The battery management circuit sits on top of a plastic board which is an Akro-Mils 40150 (3.3 x 7.7 x 0.1 inch). Mount the batteries in the plastic holders, wire them in series with the bus bars, mount the battery management circuit, then wire it in. I recommend using a 30 amp fuse as pictured. Once this is done attach a 30A (12-14AWG) Powerpole connector with 12-gauge wire.  The battery management circuit will charge the battery up to 14.2v before it automatically cuts off. The charger should be at least 14.6v.
CAT RD  W-Br
CAT TD  W-G
CAT +   Br-W
Data In    W-Bl
Data PTT   W-O
Data GND   Bl-W
$799 FT857D w/YSK857 $95 TCXO-9 $82 MH-59A8J DTMF mic (also needed for direct freq entry) $120 W4RT2.3khz ssb filter $169 Z-11pro2 $14 IBM PA-1121-0711 16V 7.5A Notebook Power Supply Adapter (ebay) $2 bridge rectifier KBPC5010 (ebay) $144 (8) 16ah 40160s lifepo4 $24/ea (bmsbattery.com or manzanitamicro.com) $3 (8) 40160S battery holders 0.40/ea $4 (8) 40160S bus bar connectors 0.50/ea $80 battery shipping Update 11-21-2011: The manufacturer has discontinued the 16ah 40160S battery and replaced it with the 15ah 40152S battery. $97 (2) 30A Battery Management PCB http://www.batteryspace.com/pcbprotectioncircuitmodulefor4cells128vlifepo4batterypackat30alimited.aspx $11 USB to serial converter http://www.usbgear.com/computer_cable_details.cfm?sku=USBG-RS232-F12&cats=199&catid=482%2C199%2C601%2C461 $8 3/8X24 Thread Mirror Mount: Wilson 901104 $5 (20') Belden 8219 (RG58A/U) $3 (4) Amphenol 83-185-RFX (UG-175 reducer) $20 (4) Amphenol 83-822 (PL259) $10 shipping (theantennafarm.com) $79 Jansport Driver 8 TN89-008 UPC 757969203361 Wheeled Backpack (buy.com) $6 dual-band (2/440) whip with 3/8x24 mount (hamstick EDBW-1, Opek DB-1, or Workman DB-1) $4 (2) WORKKW2000A or CONXPARTSA (this is the power cord and connector pins) $3 (6 feet) Red & Black DC wire 12 GA $9 shipping (k1cra.com) $11 (3') LMR-600 (showmecables.com) $1 (4) 1/4"-20 nuts (7/16" head) $1 (4) 1/4"-20 x 3/4" bolts $2 (8) 1/4"-20 wingnuts $9 (10') 4" drainpipe (we need one 7 3/4" piece) $4 (2) 4" drainpipe cap (home depot) $20 (5) littelfuse FHA30 12AWG inline fuse holder $3 (1) 5-pack of ATO 7.5 fuse (drillspot.com) $3 4' 14 gauge cable (for short part of radio power connector) (.62/ft) $1 4' 18 gauge cable (for battery sense +/- to pcb, low power wire on power cable) (.31/ft) $6 (1) 1/4" (22-18) Ring Terminal 50pcs $4 (1) 1/4" (16-14) Ring Terminal 50pcs $6 (1) 1/4" (12-10) Ring Terminal 50pcs $10 shipping (parts-express.com) (1) DB9F mouser 156-1309 0.80 (4) BC546A mouser 512-BC546A 0.10 (2) 5.6k 1/4w mouser 588-OD562JE carbon comp 5% 0.42/ea (3) 10k 1/4w mouser 588-OD103JE carbon comp 5% 0.42/ea (1) 3.5mm 3-pin plug (cw) (2 wires used) mouser 568-NYS231BG 1.69 (for cw jack) (1) 8-pin mini-din (cat) (4 wires used) mouser 171-2608 1.49 (1) 6-pin mini-din (data) (4 wires used) mouser 171-2606 1.36 (2) 600ohm 1:1 transformer mouser 42TL016-RC 1.66 (2) 51 ohm 1/4w mouser 588-OD510JE 0.42 (1) 1uf cap mouser 5989-100V1.0-F 0.71 (1) .0047uf cap mouser 140-50P5-472K-RC 50v ceramic disc 0.12 (1) 100 ohm 1/4w mouser 588-OD101JE 0.42 carbon comp 5% (1) 1k 1/4w mouser 588-OD102JE 0.42 (1) board mouser 854-PR1593K $4.10 2.6 x 2.6 (1) box mouser 546-1593KBK $2.88 (box is 2.6 x 2.6 x 1.1) (2) 2.2k resistor 1/2w carbon comp 5% mouser 588-OF222JE (1/4w mouser 588-OD222JE 0.42 not avail) (4) PL259 right angle Amphenol 083-1AP UG-646/U Mouser 523-83-1AP $14.70/ea (1) 2.5x5.5mm right angle plug (24AWG) power plug for tuner mouser 171-3216-EX $1.04/ea (2) ferrites - mouser 875-LFB187102-000 3.03/ea 3/4" OD .400" ID 1.125" long (3 turns RG58 = 1000 ohm impedance @ 1-5mhz) (2) mouser 526-WH22-00-100 100' 22awg copper 7-strand hookup wire black nteinc.com $19 (use p/n 03-100 for orange) insulation OD 0.060" (2) 3.5mm stereo jacks 502-35RAPC3BV4 2.73 $112 total $12 shipping (mouser.com) $8 (1) 14-pack 3/8 ring terminal 16-14AWG (JT&T 2011H - amazon.com) $18 (2) 8ft 3.5mm stereo cables (mediabridge - amazon.com) $3 21/64 (.3281") drill bit for 3/8-24 threads (amazon.com) $28 3' Aluminum 6061-T6 Seamless Round Tubing, WW-T 700/6, 1/2" OD, 1/4" ID, 1/8" Wall, 36" Length (amazon.com) $65 Opteka CFM300 68" 5 Section 8x Carbon Fiber Monopod (amazon.com) $209 (1) PowerFilm F15-1200 20W solar panel 10.5 x 6.5 x 0.6 1 lb (amazon.com) $11 (4) EZ-Hook XM (digi-key 461-1004-ND) $2 Akro-Mils plastic dividers (Akro-Mils 40150 wasserstrom.com) $1 (8) 3/8-24 Jam Nuts 18-8 Stainless Steel $1 (2) 3/8-24 Hex Nut 18-8 Stainless Steel $10 (5) 3/8-24 x 1-1/8 Hex Coupling Nut 18-8 Stainless Steel $1 (10) 3/8" USS Flat Washer 316 Stainless Steel $7 shipping (fastener-warehouse.com) $7 (5') 1/4" schedule 80 PVC pipe (usplastic.com) $14 (2) coleman 827E140T colthesline reel (coleman.com) $58 AT-271A/PRC antenna (ebay) OR $58 Voile Tourlight Avalanche Probe (8 foot) (voile-usa.com) $2 (2) 6" tent stakes (rei.com) $2 (1) 4-pack of 10" bungee cords (rei.com) $8 tax/shipping (rei.com) $12 (1) F-125-K Toroid Core 1.25" 250-300 permeability low loss ferrite 1-30 mhz (theaudioguru.com) $11 (1) 1/4 lb Wire, 16ga (0.05") enameled (we need 4 feet for toroid) (allspectrum.com or jameco.com) $20 (1) 79-87283 DonJoy COMFORTFORM WRIST support-Small right (expressorthopedics.com - warning, it takes them a month to ship it) $8 Cables To Go 52030 - 6ft DB9 M/F All Lines Extension Cable Black (nextwarehouse.com) $12 (1) 85085K8 25-pack nylon edge trim .065 gap width 3/16 opening, 15/64 height, 12 3/4 long $23 (1) 8871K71 80' (1 lb) spool .064" (14ga) tin coated copper wire (spool says Arcor 14AWG) $2 (1) 91187A202 1.5" 5/16-18 RHT stainless stud (or you can order a 10-pack for $4.55 with part number 95412A587) $10 (2) 95412A659 5-pack of 1.5" 3/8-24 RHT stainless stud $9 tax/shipping (mcmaster.com) ========== $2518 approximate cost $? (1) stickyback velcro (attach tuner to radio mount) $? (1) velcro wire ties (attach coax to antenna mast) $? (1) 3/8-24 tap $? (1) 5/16-18 tap $? (1) Jaycar UB5 clear jiffy box (for balun) 3x2x1" $? (4) 30A (12-14AWG) red/black powerpole connector (1 for radio, 2 for batteries, 1 for AC/DC power supply)
