GE Phoenix SX
Revision as of 23:06, 12 December 2013 by Atomic taco (Talk | contribs)
GE Phoenix SX VHF Programming GE Phoenix SX VHF Programming PROM format The PROM chip is an X2212PI GE software : no decimal points when entering freq C for carrier pl, D for DPL c670 for 67.0 STE: 0 off 1 on Phoenix SX VHF ---------------------------------------------------------------------- RX: FFFF = disabled 0000 = 118.840 rx valid: 130.000 - 190.050 RX formula: Desired Freq (5kc increments only) - 118.840(base) = X 140.600 X=21.76 x = x * 1000 (x = 21760) //convert to kc x = x / 5 (x = 4352) //convert to # of 5kc steps from base //get MSB x = x - 4096 (nearest multiple of 2048) (mult is 2 hex) remainder is 256 - 256 (nearest multiple of 128) (mult is 2 hex) remainder is 80 - (nearest multiple of 16) (mult is 5 hex) if this # is 4,5,6, or 7 then add 4 !!! (result is 9) remainder is 0... (remainder is 0 hex) mults and remainder = 2290 rearrange x by swapping 1st two bytes then swapping last two bytes = 2209 0200 = 139.320 0300 = 149.560 10.24 MHZ 0200 = 139.320 1200 = 139.960 2200 = 140.600 640 kc 0200 = 139.320 0201 = 139.400 80 kc 1183 = 130.00 11C8 = 130.100 11D8 = 130.105 11E8 = 130.110 21C1 = 130.500 21E8 = 130.750 21CA = 130.900 216B = 130.950 9102 = 135.000 C103 = 137.000 F108 = 139.000 F12B = 139.250 F16B = 139.270 F1FB = 139.315 0200 = 139.320 02F0 = 139.350 0201 = 139.400 0242 = 139.500 02EA = 139.870 028B = 139.920 1200 = 139.960 1280 = 140.00 (2108) 1201 = 140.040 12C1 = 140.100 12F1 = 140.115 1202 = 140.120 1212 = 140.125 1262 = 140.150 12F2 = 140.195 1203 = 140.200 1279 = 140.395 1289 = 140.400 12D9 = 140.425 12F9 = 140.435 120A = 140.440 122A = 140.450 12CA = 140.500 12FB = 140.595 2200 = 140.600 22E1 = 140.750 22C3 = 140.900 2209 = 141.00 820B = 145.00 9249 = 145.500 922B = 145.650 92CB = 145.700 92FB = 145.715 A200 = 145.720 A2F0 = 145.795 A201 = 145.800 A283 = 146.00 C200 = 147.00 F201 = 149.00 F24B = 149.500 F2EB = 149.550 F2FB = 149.555 0300 = 149.560 0362 = 149.750 0389 = 150.00 0400 = 159.800 0401 = 159.880 0402 = 159.960 0403 = 160.040 0408 = 160.120 0409 = 160.200 040A = 160.280 040B = 160.360 1400 = 160.440 4509 = 173.00 F681 = 190.00 ^^^^ 8 = lsb (0-f) 5 KC PER INCREMENT 1 = (0-b) 80 KC PER INCREMENT (16 STEPS OF 5KC) F = (0-f) 640 KC PER INCREMENT (128 STEPS OF 5KC) 6 = msb (0-f) 10.240 MHZ PER INCREMENT (2048 STEPS OF 5KC) ---------------------------------------------------------------------- TX: FFFF = disabled 0000 = 163.840 tx valid: 130.000 - 190.000 |------ (640kc) ||----- MSB (10.24mhz) |||---- LSB (5kc) ||||--- 0,1,2,3, 8,9,A,B (80kc) |||| BC01 = 130.000 CC89 = 131.000 AEF2 = 149.995 AE03 = 150.000 AE13 = 150.005 AEA3 = 150.050 AEF3 = 150.075 AE08 = 150.080 BE41 = 150.500 BE03 = 150.640 AF03 = 160.240 FFFB = 163.835 0000 = 163.840 0010 = 163.845 820B = 190.000 ---------------------------------------- Phoenix SX VHF Mode "A" channels: 1-8 Mode "B" channels" 11-18 default $11 = 2 (CCT) $19 = 1 (# of mode b channels - 1) $f1 = 1 (# of mode a channels - 1) Channel PL byte: 0 IF UNPROGRAMMED, OR USING CAR SQ OR TONE PL ADD 2 IF STE IS ON ADD 4 IF TX IS DPL ADD 8 IF RX IS DPL Timeout Timer values: 0=0:30 1=1:00 2=1:30 3=2:00 4=2:30 5=3:00 6=3:30 7=4:00 00 = PL byte 01 = A (always - after programmed once) 02-05 = Ch.8 RX freq 06-07 = Ch.8 RX PL 08 = ? 09 = A (always) 0A-0D = Ch.18 RX freq 0E-0F = Ch.18 RX PL 10 = 8 (always - after programmed once) 11 = Timeout timer ("Carrier Control Timer" or CCT) 12-15 = Ch.8 TX freq 16-17 = Ch.8 TX PL 18= 19 = (# of Mode B channels) - 1 (valid range 0 thru 7) 1A-1D = Ch.18 TX freq 1E-1F = Ch.18 TX PL 20 = PL byte 21 = A (ALWAYS) 22-25 = Ch.1 RX freq 26-27 = Ch.1 RX PL 00 for carrier squelch, 31 for DPL 023 28 = 29 = 2A-2D = Ch.11 RX freq 2E-2F = Ch.11 RX PL 30 = 8 (ALWAYS) 31 = 0 (ALWAYS) 32-35 = Ch.1 TX freq 36-37 = Ch.1 TX PL 38 = 8 IF UNPROGRAMMED 39 = 0 IF UNPROGRAMMED 3A-3D = Ch.11 TX freq 3E-3F = Ch.11 TX PL 40 = PL byte 41 42-45 = Ch.2 RX freq 52-55 = Ch.2 RX freq 60 = PL byte 62-65 = Ch.3 TX freq 72-75 = Ch.3 RX freq 80 = PL byte 82-85 = Ch.4 TX freq 92-95 = Ch.4 RX freq A0 = PL byte C0 = PL byte E0 = PL byte E2-E5 = Ch.7 TX freq F1 = (# of mode A channels) - 1 (valid range 0 thru 7) F2-F5 = Ch.7 RX freq Ch.1 rx 118.840 nopl tx 163.840 nopl STE:off Hex table 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 7 0 0 0 0 0 0 0 1 0 0 0 0 0 0 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 4 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 6 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 7 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 C 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 D 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 E 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 F 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 P L none 2 2 A 0 3 8 9 0 0 4 A F F F F 0 0 67.0 2 2 A 0 3 8 9 1 0 4 A F F F F 0 0 71.9 2 2 A 0 3 8 9 2 0 4 A F F F F 0 0 74.4 3 0 77.0 4 0 79.7 5 0 82.5 6 0 85.4 7 0 88.5 8 0 91.5 9 0 94.8 A 0 97.4 1 2 100.0 B 0 103.5 C 0 107.2 D 0 110.9 E 0 114.8 F 0 118.8 0 1 123.0 1 1 127.3 2 1 131.8 3 1 136.5 4 1 141.3 5 1 146.2 6 1 151.4 7 1 156.7 8 1 162.2 9 1 167.9 A 1 173.8 B 1 179.9 C 1 186.2 D 1 192.8 E 1 203.5 F 1 210.7 0 2 D023 2 A A 0 3 8 9 3 1 4 A F F F F 0 0 D025 5 1 D026 6 1 D031 91 D032 A1 D036 E1 D043 32 D047 72 D051 92 D053 B2 D054 C2 D065 53 D071 93 D072 A3 D073 B3 D074 C3 D114 C4 D115 D4 D116 03 D122 25 D125 55 D131 95 D132 A5 D134 C5 D143 36 D145 56 D152 A6 D155 D6 D156 E6 D162 27 D165 57 D172 A7 D174 26 D205 D5 D212 A8 D223 39 D225 59 D226 44 D243 3A D244 E7 D245 5A D246 6A D251 E9 D252 AA D255 DA D261 79 D263 B8 D265 97 D266 6B D271 9B D274 CB D306 76 D311 9C D315 DC D325 5D D331 9D D332 AD D343 4D D346 6E D351 9E D356 EE D364 85 D365 74 D371 F8 D411 F4 D412 75 D413 B5 D423 C9 D431 2B D432 EB D445 29 D446 30 D452 50 D454 60 D455 70 D462 80 D464 F9 D465 E2 D466 46 D503 F6 D506 49 D516 TRANSLATES TO D654 37 D523 90 D526 A0 D532 17 D546 FC D565 7C D606 B6 D612 CA D624 D3 D627 F1 D631 99 D632 35 D654 37 D662 3F D664 4E D703 86 D712 E5 D723 D9 D731 40 D732 47 D734 63 D743 AC D754 E3
