Triplett Meters
630
| 630 type 5 | Taut | 600 | 120mA | x | aka model 3030. 30v(413/210) battery. female banana probes | |||
| 630-A type 3 | x | |||||||
| 630-M type 1 | ||||||||
| 630-PL type 5 | x | |||||||
- L = low power ohms
- K = protection circuit
- PLK = protection circuit
- APLK = both the above
