Mount Rainier National Park
Frequencies
169.7250 | Main Park/LE |
163.7125 | Common 2 |
168.6125 | Common 1 |
163.0650 | |
169.9000 | USFS F1 |
156.1350 | OSCCR (203.5) |
159.0900 | Buckley Fire (Dispatched by Fife PD), Medic 35 often closes ALS unit (AMR unit with AMR Paramedic and Buckley Fire EMT on board) |
Dispatch | Park Comm Center located at Tahoma Woods |
Enumclaw | Enumclaw Police Dispatch used in evening and some holidays for "LE units" (Law Enforcment) |
Unit 100 | Park Superintent |
Most 7** | Units are Park LE |
Forest 55 | USFS LE (Dispatched by Bellevue WSP) |
Aid 4031 | NPS Aid Unit (Paradise) |
Aid 4032 | NPS Aid Unit (White River) |
Radio Terms
Radio Channels
Channel Name | Area Covered |
Paradise | Nisqually Entrance to Paradise. Longmire, Upper Stevens Canyon Rd. |
TWoods | Longmire to Eatonville. |
Gobblers | Nisqually Entrance to Tahoma Woods, Southwest backcountry |
Packwood | Skate Creek Rd., Packwood, Box Canyon to Backbone Ridge on Stevens Canyon Rd. |
Shriner | Ohanapecosh to Cayuse Pass, Chinook Pass, Sunrise, Lower Stevens Canyon Rd. |
Crystal | Cayuse Pass to Enumclaw, White River, Sunrise Road, Northeast backcountry |
Sunrise | Sunrise area |
Fremont | North backcountry, areas above Sunrise |
Tolmie | Carbon River, Mowich Lake, Eatonville, Enumclaw, Northwest backcountry |
West Direct | Local-area use, Westside ranger district |
East Direct | Local-area use, Eastside ranger district |
