Yaesu VX-7R
Revision as of 16:56, 6 April 2013 by Rich (Talk | contribs)
F + pwron = clone
Alignment:
Press HM/RV to save changes and exit  (I used to use F HM/RV but it appears pressing F first isn't necessary)
Default values:
TN 167.9        11        16
MAX DEV (2m): 81=4.5kc
