Yaesu VX-7R
Alignment:
Note that power & deviation levels have separate settings for low-end and high-end of the band When you get to the power or deviation settings press MONI/F to toggle between the low-end and high-end settings
Default values:
50 52 54 144 145 148 220 222 225 430 435 440
