Triplett Meters
630
630-A type 2 | Susp | 6000/1200 | 12A | 60uA | x | banana probes | ||
630-A type 3 | x | |||||||
630-APL | 1970-? | 5000/1000 | 10A | 100uA | x | banana probes | ||
630-M type 1 | ||||||||
630-NA type 3 | Susp | 6000/1200 | 12A | 120uA | x | x | 30v(413/210) batt. Some 6000(Red)/1200,others 1200 only. banana probes. #3042? | |
630-NS type 3 | Susp | 1200 | 12A | 120uA | x | x | 200K/v instead of 20K/v sens. banana probes #3102 | |
630-PL type 5 | x | |||||||
- L = low power ohms
- K = protection circuit
- PLK = protection circuit
- APLK = both the above
