Triplett Meters
630
| 630-A type 3 | x | |||||||
| 630-M type 1 | ||||||||
| 630-PL type 5 | x | |||||||
- L = low power ohms
- K = protection circuit
- PLK = protection circuit
- APLK = both the above
