Triplett Meters
Revision as of 00:04, 30 March 2013 by Rich (Talk | contribs)
630
Model Years Mvmt PeakV PeakA LowA Mirror Doubler Notes
630 1949-? Jewl 6000/1200 12A 60uA banana probes
630 type 3 Susp 6000/1200 12A 100uA 20K/v. banana probes
630 type 4 Jewl female banana probes
630 type 4 Susp 600 120mA female banana probes
630 type 5 Jewl 600 120mA x female banana probes
630 type 5 Taut 600 120mA x 30v(413/210) battery. female banana probes
630 type 6 2007? Taut 600 120mA 300uA x aka model 3030. female banana probes
630-A 1953-? Jewl 6000/1200 12A 60uA x 30v(413/210) battery. banana probes
630-A type 3 x
630-APL 1970-? 5000/1000 10A 100uA x banana probes
630-APL type 4 Susp 5000/1000 10A 100uA x banana probes
630-APL type 5 1980? 30v(413/210) battery
630-APLK -1976? Jewl 5000/1000 10A 100uA x
630-L type 2 Jewl 5000/1000 10A 100uA banana probes
630-M 1Meg/Volt sens.
630-M type 1
630-NA 6000/1200 12A x x banana probes
630-NA type 1 banana probes
630-NA type 2 5000/1000 10A banana probes
630-NA type 3 Susp 6000/1200 12A 120uA x x 30v(413/210) batt. Some 6000(Red)/1200,others 1200 only. banana probes
630-NA type 4 Susp 1200 12A 120uA x x banana probes
630-NS 200K/v instead of 20K/v sens. banana probes
630-NS type 2 Susp 6000/1200 12A 120uA x x 200K/v instead of 20K/v sens. banana probes
630-NS type 3 Susp 1200 12A 120uA x x 200K/v instead of 20K/v sens. banana probes #3102
630-PL 1976-? Jewl 5000/1000 10A 100uA banana probes
630-PL type 2 5000/1000 10A 100uA banana probes
630-PL type 3 5000/1000 10A 100uA some? banana probes
630-PL type 4 Susp 5000/1000 10A 100uA banana probes
630-PL type 5 1980? Susp 1000 10A 100uA 30v(413/210) battery. banana probes
630-PL type 5 x
630-PL type 6 600 120mA x
630-PL type 6 Taut 1000 10A x
630-PLK -1976? 5000/1000 10A 30v(413/210) battery. banana probes
A = higher precision than non-A
S = very high sensitivity (200K/v)
M = super high sensitivity (1M/v)
L = low power ohms
N = includes range doubler switch
P = polarity reversal switch ?
K = protection circuit
APL = higher precision than A + low power ohms
PLK = protection circuit
APLK = both the above
PL = all the above (1976 and later)
Some information sourced from postings by Fred Scoles
