Triplett Meters
630
630-A type 3 | x | |||||||
630-APL | 1970-? | 5000/1000 | 10A | 100uA | x | |||
630-M type 1 | ||||||||
630-PL type 5 | x | |||||||
- S = very high precision
- M = super high precision
- L = low power ohms
- K = protection circuit
- PLK = protection circuit
- APLK = both the above
