Triplett Meters
630
630 type 3 | Susp | 6000/1200 | 12A | 100uA | 20K/v banana probes | |||
630-A type 3 | x | |||||||
630-APL | 1970-? | 5000/1000 | 10A | 100uA | x | |||
630-M type 1 | ||||||||
630-NA type 1 | ||||||||
630-NA type 2 | 5000/1000 | 10A | ||||||
630-PL type 2 | 5000/1000 | 10A | 100uA | |||||
630-PL type 3 | 5000/1000 | 10A | 100uA | some? | ||||
630-PL type 5 | 1980? | Susp | 1000 | 10A | 100uA | 30v(413/210) battery | ||
630-PL type 5 | x | |||||||
- L = low power ohms
- PLK = protection circuit
- APLK = both the above
