Mount Rainier National Park
Revision as of 00:46, 10 October 2012 by Forest3433 (Talk | contribs)
169.7250   Main Park/LE
163.7125   Common 2
168.6125   Common 1
163.0650
169.9000   USFS F1
156.1350   OSCCR (203.5)
159.0900   Buckley Fire, Medic 35 often closes ALS unit (AMR unit with AMR Paramedic and Buckley Fire EMT on board)
Unit 100   Park Superintent
Most 7**   Units are Park LE
Forest 55  USFS LE
Aid 4031   NPS Aid Unit (Paradise)
Aid 4032   NPS Aid Unit (White River)
Radio Term's
RADIO CHANNELS
There are 15 total channels used in the park for radio communications in three groups: Admin Net channels,
Common-Use channels, and the Portable Repeater channel.
The following channels form what is known as the Admin Net, which is the Park’s main radio system. Its primary
purpose is for emergency and safety communications and secondary for general-purpose use where employees can
communicate with each other to help perform their duties.
The first nine channels are ‘repeater channels’, and the name designates the location of the repeater.
Repeaters are used to take your transmitted radio signal and spread it out from the repeater’s location
over a wider area so you can communicate with others in range of the repeater.
All of the eleven Admin Net channels receive on the same frequency. Because of this, you will hear any
and all radio traffic that is within range of your radio, regardless of which Admin Net channel you might
be on (i.e. your radio is on PARADISE but you’re hearing radio traffic from others on SHRINER).
DIRECT should only be used when it is ineffective to use repeater channels. This can happen when communicating
a very short range (less than 200 feet) away from the other party (i.e. letting a road crew member know you are
right behind their machinery before you pass them) or if a repeater fails. DIRECT should not be used for routine
communications – if you need to communicate short-range, use a common use channel instead.
The next three channels COM 1, COM 2, and COM 3 are known as both common-use and off-net channels, meaning
that they are stand-alone channels that are not a part of any radio system.
Note: The ‘Portable Repeater’ channel is used when temporarily deployed during incidents for providing coverage
in a specific area and/or for operations that require frequent radio usage and not tie up the Admin Net
(such as helicopter operations for a wildland fire or SAR incident).
