Revision as of 05:06, 3 September 2012 by Rich (Talk | contribs)
Its best to only use HDPE #2 or PP #5 containers. Other containers can leach chemicals into the water. Do not use 2-liter soda bottles (PET #1) for long term water storage ! You can use 2-liter bottles for short term rotated storage (6 months) provided you keep the bottles out of sunlight. Another thing to note is you should never use plastic milk containers for water storage.
You can improve the filtering by cutting the bottom off a 2 liter bottle, putting cloth or a coffee filter over the neck from the inside, packing it with granulated campfire charcoal then putting about 2 inches of sand on top. Pour water over the sand and wait for it to drip out.
Boil it for 10 minutes
Cool it for 30 minutes
For filtering, figure on 30-80 microns for sand and 10-20 microns for a coffee filter.
A person should consume about 1 to 1.5 gallons of water per day and more if you are in a hot and dry climate. In any case, the liquid leaving your body should be at least 1/2 quart per day. If your breathing and heart rate are faster than normal its probably a sign that you are suffering dehydration.
For extreme survival situations where you have a limited amount of water and want to use an absolute bare minimum amount, you can add 2 teaspoons of sugar per quart of water and drink about 1/2 quart per day. This isn't the healthiest way to do things but it should keep you alive.
