Its best to only use HDPE #2 or PP #5 containers. Other containers can leach chemicals into the water. Do not use 2-liter soda bottles (PET #1) for long term water storage ! You can use 2-liter bottles for short term rotated storage (6 months) provided you keep the bottles out of sunlight. Another thing to note is you should never use plastic milk containers for water storage.
Boil it for 10 minutes
Cool it for 30 minutes
For extreme survival situations where you have a limited amount of water and want to use an absolute bare minimum amount, you can add 2 teaspoons of sugar per quart of water and drink about 1/2 quart per day. This isn't the healthiest way to do things but it should keep you alive.
