Using bleach in these ratios (1 drop per quart, 1/4 teaspoon per 5 gallons, or 2.75 tsp per 55 gallons) will result in about 3.2-3.5 ppm of chlorine in the water. For comparison chlorinated tap water (and swimming pool water) usually has 1-3ppm of chlorine. The EPA limit for tap water is 4ppm.
Boil it for 10 minutes
Cool it for 30 minutes
