Revision as of 20:33, 2 September 2012 by Rich (Talk | contribs)
Treat you water with regular (non-scented) Clorox which contains 5.25%-6% sodium hypochlorite.
Using bleach in these ratios (1 drop per quart, 1/4 teaspoon per 5 gallons, or 2.75 tsp per 55 gallons) will result in about 3.2-3.5 ppm of chlorine in the water. For comparison chlorinated tap water (and swimming pool water) usually has 1-3ppm of chlorine. The EPA limit for tap water is 4ppm.
Its best to only use HDPE #2 or PP #5 containers. Other containers can leach chemicals into the water. Do not use 2-liter soda bottles (PET #1) for long term water storage ! You can use 2-liter bottles for short term rotated storage (6 months) provided you keep the bottles out of sunlight.
