Revision as of 00:15, 11 December 2011 by Rich (Talk | contribs)
These movements are usually 21 jewel and a number of the 82xx series movements also provide day/date. These movements support both automatic winding and manual winding. The only drawback is these movements don't "hack". "Hack" means the second hand stops when you pull out the knob to set the time. This is important if you want to adjust your time to be accurate down to the second. It also gives you the ability to accurately synchronize your watch with another persons watch. Miyota movements are often found in Citizen, Bulova, Miyota, and Wittnauer brand watches and are usually in the $190-$250 range.
Seiko 6R15/6R20
