It is currently Wed Nov 19, 2025 6:33 am
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: POCSAG & PDW v2.53
PostPosted: Sun Jun 21, 2009 2:22 pm
I see the WDT2000 has Mobitex. It is used in this area much? Any frequencies of interest?
Not that I know of.
PostPosted: Sun Jun 21, 2009 4:36 pm
From 2004
; sample text scan strings
"fema "
"swat"
"secret "
"navy"
"police"
"port townsend"
"whidbey"
"jefferson"
"potus"
"coast guard"
"fed "
(CAPCODES)
; pager capcodes
; Pocsag capcodes must be exactly 7 digits enclosed in {}
; Short FLEX capcodes are exactly 7 digits enclosed in []
; Long FLEX capcodes are exactly 9 digits enclosed in []
; Golay capcodes are exactly 6 digits enclosed in ()
; The entry will be ignored if you don't match one of the four
; cases listed above.
; The list is searched from the top down for the first match, so
; you may want to put capcodes with wildcards later.
; Use '?' as a wildcard character.
; Text description of up to 30 characters can be included.
; Right now you can have up to 400 addresses in this list.
; Example POCSAG capcodes
(0302522}vickptbnkcnt
{0010289} SPD INTEL/PEACE
{0017297}SNO BUS
{0021877}ert
{0021877}sp swat jon
{002866414}irs?
{00287072}SEA SWAT
{002881545}JEFF GEN
{002881828} SPD INTEL/PEACE
{002931390}NEED SWAT MEDIC
{002931419}MISSING EMAIL FED?
{002931486}MISSING EMAIL FED?
{003118547}RE:JEFF GEN
{003161364}PD NET LIST?
{003285126} POLICE ONE RE:THRET LEVEL
{003341857}PD NET LIST?
{004024943}SEA SWAT
{0052303}kc com
{0070895}sp swat
{0091516}irs?
{0094890} Rapid assult team/ kirkland
{0133232}oat1 unway pt firenotlaunch
{0134065}wsfpt alrm
{0134079}wsfpt alrm
{0151908}METRO? BUS
{0153014}SEA SWAT
{0153844}g1 sp/ops sgt
{0156241}POLICE ONE RE:THRET LEVEL
{0180935}SEA SWAT
{0203057}ptpdprntperson
{0218465}komo tim
{0225857}kcair swat
{0227252}sp swt jon
{0302077}POLICE ONE RE:THRET LEVEL
{0302522}arg gng ptbrnch
{0322429} Rapid assult team/ kirkland
{0333698}fb1
{0348309}bln2pt circ
{0354602}SEA WH POWDER CALL
{0394979}arm ? mcch
{0395064}COMPUTER FIX SPD
{0414352}ms?
{0437969}nurce frm pt
{0441256}ptperson
{0443028}snofir
{0443149}snocom ares
{0443189}oat4
{0444135}SWAT
{0466789}s ct 48 ollivr
{0476818}cal vanpd-lapson
{0497735}SEA WH POWDER CALL
{0515074}oat3
{0515557}SEA WH POWDER CALL
{0515584}SEA SWAT
{0554361}snofir
{0556567}snofir
{0568663}st sp op2
{0586031}ms?
{0598697}Whidb capsiz boat
{0615142} tv httc list
{0616590}SNO BUS
{0628099}news
{0630957}kennmn/list-comp?
{0649672}SGT Mich.SP call re Tranining
{0667940}doe tlk u
{0702850}eoc oem rep
{0707235}bushpt bot blow smk
{0715069}SNO BUS
{0731000}COMPUTER FIX SPD
{0738229}Rapid assult team/ kirkland
{0769440}kc br fb
{0780341}eoc jim
{0780863}calfema
{0789852}st eoc dian
{0800393}ms sec
{0801062}oat2
{0801338}POLICE ONE RE:THRET LEVEL
{0832930}notpd prezcanvisit
{0918640}p collpt?
{0919252}garlemon
{0942822}jail?
{0946038}stgov
{0995373}pt2blyn circ
{0995541}br?
{0995647}lfswat
{1003637}tv collin
{1012240}SNO BUS
{1020771}ms?
{1022982}SWAT
{1023813}SWAT
{1040544} SPD INTEL/PEACE
{1040749}POLICE ONE RE:THRET LEVEL
{1041750}SEA SWAT
{1041794}ms?
{1041860}rpt airfire
{1041861}rpt airfire
{1041863}rpt airfire
{1054226}NEED SWAT MEDIC
{1058042}NEED SWAT MEDIC
{1089377}SEOO RE FEMA TRHET LEVEL
{1159184}cal gefgen
{1159895}FED-LINE FAIL ON PC
{1159916}FED-LINE FAIL ON PC
{1162856}cal gfgen
{1170896}NCIC LIST
{1293916}sp spop lary
{1293977}ssorod
{1293996}g1 jim
{1293996}kcsar/gardian1 jim
{1294021}kc sp op airport
{1294184}kc com
{1313418{wsfpt arlm
{1319754}SEA SWAT
{1321073}whidbey fire?
{1323195}port police ?
{1328822}POLICE ONE RE:THRET LEVEL
{1329217}SEA SWAT
{1343893}mark
{1355405}komo
{1355406}komo
{1400895}SWAT
{140705}tv?
{1407248}swat
{1415272}jos
{1422179}kc eoc eom
{1434578}SEA SWAT
{1453635}SEA SWAT
{1453635}SPD INTEL-PEACE/swat
{1453843}FED-LINE FAIL ON PC {1205875}P POWER PT
{1500390}swat?
{1527065}Dr Royal (re PT patient)
{1531482}SWAT
{1562810}st eoc kcesar
{1564363}SEA WH POWDER CALL
{1564386}SEA WH POWDER CALL
{1581370}SEA WH POWDER CALL
{1590534}SEA WH POWDER CALL
{1590601}SEA WH POWDER CALL
{1590647} METRO? BUS
{1600085}?firenet
{1614657}SEOO RE FEMA TRHET LEVEL
{1628609}FED-LINE FAIL ON PC
{1628611}FED-LINE FAIL ON PC
{1628615}FED-LINE FAIL ON PC
{1632289}SEA CG P36
{1637177}tv
{1703586}SEA CG P36
{1723635}POLICE ONE RE:THRET LEVEL
{1789093}swat?
{1807816}NEED SWAT MEDIC
{1847801}SPD SWAT
{1945190}SEOO RE FEMA TRHET LEVEL
I pulled Sean's from the list see if you can find it.
PostPosted: Sun Jun 21, 2009 4:38 pm
No.
You could try these:
http://interceptradio.com/s.php?sfreq=1 ... unty=1&z=1
Doubt you'll find much happening. It's been a "dead" system for years.
PostPosted: Wed Jun 24, 2009 5:05 pm
After playing with this a bit, it seems like signal strength plays a big part in solid decode. I just did a D-tap on my PRO-97 and I'm getting SFD pages perfectly, but having zero luck with ValleyCom. Of course, I'm just using the duck antenna. I'm going to try a different antenna shortly and see if that makes much of a difference.
Also, I read that VC pages in POCSAG 1200, but almost of the pages I see (and can hear) are coming across as POCSAG 512, with no message decode. Think that might be a signal strength issue? Prior to the D-Tap I was receiving a fair number of VC pages, albeit with jumbled and garbled text.
Rob
N7LXI - Seattle
PostPosted: Wed Jun 24, 2009 5:42 pm
do VC have text pages? it could just be a pager code for alert type your picking up.
PostPosted: Wed Jun 24, 2009 6:03 pm
Are there new scanners coming out with D-Tap already available?
PostPosted: Wed Jun 24, 2009 7:34 pm
Yes, ValleyCom does their paging on 152.0075. I've decoded the pages in the past, just not having any luck now.
Rob
N7LXI - Seattle
PostPosted: Wed Jun 24, 2009 7:43 pm
Snohomish County, EPSCA, and Valley Comm. are on 152.0075
PostPosted: Wed Jun 24, 2009 7:54 pm
I'll try it and give it a shot.
Did you make the little RC filter for your d-tap? Well, I just looked up the Pro-97 instructions and others just recommend using a 10k resistor. So you may not need the capacitor. (I have a 10K and a .01uF cap with my Pro-2006 - which cuts off the bandwith to roughly 6k.)
Also be sure your PDW is set to the "discriminator" option in the setup.
PS. POCSAG decoding is 100% for me. Flex decoding is roughly 95%... I still get subtle errors with the Flex decoding. My mic input volume is set at 50% with NO mic boost. I've tried 25% and 100% but with more errors.
-Nick
PostPosted: Wed Jun 24, 2009 10:29 pm
Have you tried the Line input?
PostPosted: Thu Jun 25, 2009 4:59 am
Yeah, 10k resistor and I'm using the discriminator option in the setup...and as I mentioned SFD is 100%. I'm working today, but I'll play with it more tomorrow...
Rob
N7LXI - Seattle
PostPosted: Thu Jun 25, 2009 5:09 pm
Excellent tip there Taco! It's decoding extremely fast now and almost perfectly. So far just one page has an error and it's been going for about 20 minutes. It's far more accurate than before.
PostPosted: Thu Jun 25, 2009 5:14 pm
EPSCA is on 931.2125 - at least Bellevue Fire is...
{0193263}
FYI, a lot of pagers from KCFIREMED are on this frequency as well. I believe EMS people... assigning of shifts, etc.
PostPosted: Thu Jun 25, 2009 5:46 pm
yes
PostPosted: Thu Jun 25, 2009 10:21 pm
I spent a bunch of time checking the 900 pagers in 2004 and 90% of all the action is on 931.2125
