It is currently Fri Aug 14, 2026 12:21 pm
PostPosted: Wed Dec 29, 2010 2:13 am
Now Click "Modern Music". Still owned by Sandusky; the format is "modern AC/alt-gold", what I can only liken to a hybrid of KGY-FM and KNDD-FM's gold. Inagurating themselves with 10,000 songs (along with legal IDs and sweepers). I normally only listen to KNHC-FM, but I've been listening for the past 20 minutes and it's not bad. Better than KJAQ-FM.
Arbitron shows they were going downhill, not that three months is any indication
Flip was some time on Dec 27. Radio Info has some good banter.
PostPosted: Wed Dec 29, 2010 7:57 am
I used to listen to that station, streamed it when I was in Georgia.
PostPosted: Mon Feb 28, 2011 11:26 pm
Where are all the AM stations ???? Turn off all the AM's and save the electric power. Another good reason to take the lower TV channels - from 2 - 6 and turn them into a new FM band and move all the AM stations over to the new FM band. Thats not going to happen - but whats even worse is giving any UHF TV channel over for wireless cellphone use -- as proposed by the FCC.
PostPosted: Tue Mar 01, 2011 11:54 am
AM all-night radio shows used to be of interest.
Nothing but sports, gawd & politics now.
PostPosted: Tue Mar 01, 2011 3:39 pm
You can't take away the last granted 50,000 watt licensed monster KTNN in Window Rock Arizona
PostPosted: Tue Mar 01, 2011 5:21 pm
Take away a 50,000 watt blow torch -- NO WAY. BUT -- get rid of all the dead wood !!. Take a look at the ratings. ALL are FULL POWER -- Day & Night operations with 5,000 watts or more. AND all are almost below 1200 Khz. The lower band - with better coverage. ALL of the top AM stations have a power of at least 5 KW. Get rid of all daytimers -- and make a limit of 1 kw Day + Night for all stations. Clean up the AM band -- and move all the other stations over to a NEW FM Band. --- MOVE all low powered TIS stations over to FM as well. TV channels 2 - 3 + 4 (54 - 72 Mhz) as a new "Over flow FM Band" for low powered local FM and TIS stations. TV channels 5 & 6 (76-88 Mhz) as the extended FM band -- for all of the AM Daytimers to relocate to. Give AM stations a FM Classed channel -- equal to or better than the existing AM coverage area.
PostPosted: Tue Mar 01, 2011 6:10 pm
No I want the 530-1610 monsters to stay where they are. It's a source of entertainment, especially the one at George.
PostPosted: Tue Mar 01, 2011 8:02 pm
That George station is about as good as it gets. Too bad they are low power. They should buy the LORAN antenna down the road.
PostPosted: Tue Mar 01, 2011 9:34 pm
Is that the farm radio network one?
PostPosted: Tue Mar 01, 2011 9:38 pm
Yep, a little above HAAT mounted on the sign
PostPosted: Wed Mar 02, 2011 4:37 am
I agree -- leave all of the power house stations on the AM Band. But any station - that remains as a "Daytimer" or is below 1 KW -- move off the band to FM. Clear UP the AM band. Make it clear again. Get rid of Digital on AM - it doesn't work. Nor is it needed. Give more room for other stations to increase power.
