It is currently Fri Aug 14, 2026 3:45 pm
 Post subject: Homemade TV Antenna
PostPosted: Mon Oct 26, 2009 9:04 am
Anyone build up anything from copper wire and for inside?
I'm thinking about making a 'V' centered/pointed towards the trans site.
Since any store antenna with 'HDTV' written on it is a rip-off.
 Post subject: Re: Homemade TV Antenna
PostPosted: Mon Oct 26, 2009 9:27 am
Just make sure to point your elements like this:
(transmitter)
V
V
V
You'll notice some TV antennas have straight elements while others have "V" elements. Antennas with straight elements typically have one element per channel. Antennas with "V" elements use a single element for multiple channels and/or are designed for long range. The reason for this is because a dipoles pattern tends to spread toward the ends as you get away from its resonant frequency, so you bend the elements a little to keep its pattern pointed straight.
Personally I would just buy an antenna from a discount outlet like Stark Electronic. Its hard to beat the gain of a commercial product with homebrew stuff.
PostPosted: Mon Oct 26, 2009 10:27 am
This looks pretty cool from Stark.
