It is currently Fri Aug 14, 2026 5:52 pm
 Post subject: KMCQ 104.5 C-2 Upgrade
PostPosted: Wed Aug 26, 2009 1:47 pm
The FCC has granted KMCQ - 104.5 Covington a CP to relocate to Cougar Mtn and upgrade to class C-2 -- with an ERP of 8 KW. Lot better coverage over Everett. KAFE Bellingham to move from 104.3 to 104.1 and "Shore FM" Vancouver, BC will move from 104.1 to 104.3. A Tit for Tat swap. KBCB FM in Forks, WA. has already moved from 103.9 A to 96.7 A. The old KMCQ FM site on Radio Hill just east of Enumclaw would make a good two-way site again.
PostPosted: Wed Aug 26, 2009 4:36 pm
FM is getting crowded
PostPosted: Wed Aug 26, 2009 10:39 pm
Maybe next time someone can boot KMIH off completely.
PostPosted: Thu Aug 27, 2009 3:10 am
The very best thing that the FCC could do -- is to take the lower VHF TV channels -- 2 through 6 , and "re-allot" the 54 to 88 Mhz spectrum to FM Broadcasting -- and move most of the AM Broadcast stations over to the new FM band. Then restrict AM stations to a Minimum full time power of at least 1,000 watts -- day and night. There is no longer a need for "daytime only" AM stations. (And yes -- I know that there would be a "gap" between 72-76 Mhz). But it would also provide room for new local area -- low power "community fm" stations all over the US and in EVERY Large "Metro" city like Seattle, Los Angeles and New York. It would also make the "AM Band" listen-able again. MTM
PostPosted: Thu Aug 27, 2009 10:17 am
When I was stationed in Japan I noticed the FM stations were on 76 to 90 MHz.
According to wikipedia...
"In March 2008, the FCC requested public comment on turning the bandwidth currently occupied by analog channels 5 and 6 (76–88 MHz) over to extending the FM broadcast band when the digital television transition is completed in February 2009.[1] This proposed allocation would effectively assign frequencies corresponding to the existing Japanese FM radio service (which begins at 76 MHz) for use as an extension to the existing North American FM broadcast band."
PostPosted: Sun Sep 13, 2009 11:12 am
Hi Mike, Any time frame for the switch between KAFE & "Shore FM"?
I believe KAFE has their transmitter on Orcas Is.
PostPosted: Sun Sep 13, 2009 2:22 pm
I hear that everyone has already moved -- or are in the process of relocating. The 104.5 has gone silent -- and also in the process of moving the equipment up to Cougar Mtn. 104.5 will be located on the old "KRAB 107.7" tower that was shared with 94.1, 102.5 and 107.7 before most moved elsewhere. The newer tower next door has atleast one or more UHF TV stations (TBN, etc). I have used this site before -- myself. Good coverage -- and even a better shot and coverage into the Downtown Seattle/Tacoma areas as well as along the sound shoreline areas. It covers better into the lower levels -- than Tiger Mtn. The 104.5 and the 104.9 (That I had the FCC drop in) both covered South Seattle and Tacoma well. They may not be Big money makers -- but they can or will provide another radio signal into a Market Area that can be "as dull as a farmer from Britt, Iowa". (Sorry BHT, it was a joke)
PostPosted: Sun Sep 13, 2009 2:34 pm
I just checked and KAFE is still on 104.3. I can't hear anything on 104.1
PostPosted: Sun Sep 13, 2009 2:55 pm
Just did some tweeking and found "Shore FM" on 104.1. KAFE is pretty strong
here and kind of swamps it out.
Shore FM
http://en.wikipedia.org/wiki/CHHR-FM
KAFE FM
http://en.wikipedia.org/wiki/KAFE
PostPosted: Sun Sep 13, 2009 7:15 pm
Thanks Jim. Keep an ear open and as soon as they swap channels -- the 104.5 will be back "on the air". MTM
PostPosted: Sun Sep 13, 2009 8:10 pm
Mike, what happened to the KXXO site on Rooster Rock, is it no more?
PostPosted: Sun Sep 13, 2009 9:49 pm
The present site is on Rooster Rock -- about halfway between Centralia-Chehalis and Morton. KXXO has an Auxilary back up site near Tenino. KXXO also has a CP to relocate the Main site from Rooster Rock to South Mtn - north of Shelton - where all of the other "Move ins" are located. South Mtn and Tiger Mtn are just over 65 miles (105 KM) from each other. That's the distance that the FCC requires class C stations to be spaced from each other -- ( ie: 95.7 to 96.1, 96.1 to 96.5). Other Stations on South Mtn are 99.3 KDDS-FM, 97.7 Komo-FM, 96.1 KXXO and an application for 93.7 KANY.
