It is currently Sat Sep 12, 2026 1:17 am
 Post subject: The big DTV switch...
PostPosted: Tue Feb 17, 2009 4:11 pm
Are you ready????
I am ready to quit hearing about how to plug in a wire into an obsolete box.
On the news they have a special segment covering the ...
...oh geez never mind.
:horse:
PostPosted: Tue Feb 17, 2009 4:30 pm
Looks like no major stations in Seattle/Portland/Los Angeles will be shutting down analog today.
ABC/NBC/PBS will be shutting down analog in the Spokane / Yakima / Tri-Cities areas.
PostPosted: Tue Feb 17, 2009 6:58 pm
are they gonna play the national anthem at midnight? with a flag.. or the Indian with trash?
the best part. wed for wheel of fortune, jeopardy and price is right they are gonna get a million calls that they are off the air and something is wrong.
PostPosted: Tue Feb 17, 2009 8:17 pm
I prefer the Indian Head. Unfortunately I doubt there are any operational Monoscopes at TV stations anymore.
All those funky markings etched into the Monoscope were very useful back in the days when TV transmitters had to be constantly adjusted due to tube degradation.
PostPosted: Tue Feb 17, 2009 8:39 pm
This is probably a dumb question but what are the VHF freqs that the analog channels were on going to be used for?
Most or all of the digital channels are on UHF aren't they?
PostPosted: Tue Feb 17, 2009 10:18 pm
Most VHF stations were loaned UHF channels so they could simulcast prior to the transition. After the transition many of them will reclaim their VHF channels (more range for less power as compared to UHF). At least this should hold true for highband VHF channels 7-13. Talk around town says that lowband stations won't be going back. Of course channel 2 is the worst because it is the most prone to impulse noise from electrical motors. Impulse noise on analog simply means a few static lines across the screen. On digital it wreaks havoc because it drives the bit error rate up so high that the picture will intermittently freeze and have a lot of issues with pixellization artifacts roaming all over the screen. Personally I'd take the analog noise because at least the picture is still reasonably pleasant to view. Anyways channels 2 and 3 are probably toast and channels 4 through 6 are questionable at best. Of course the best use for the spectrum would be FM expansion as it would free up a lot of bandwidth for all those low power pirate stations. Whatever the case, I hope they don't put a bunch of digital crap down there and bleed a bunch of junk into the 72-76mhz band as it would terrorize remote-controlled aircraft, link transmitters, and airport marker beacons.
PostPosted: Wed Feb 18, 2009 12:28 am
what is going on now I have cable. Has somthing changed today
PostPosted: Wed Feb 18, 2009 2:58 pm
if you have cable then your really in for it... The FCC will actually be watching you now rather then you watching TV.
nothing cable wont loose analog for another 4-400 months depending on yoru provider and other influential factors.
PostPosted: Wed Feb 18, 2009 7:22 pm
(Scratchy old lady chain smoker voice)
"Edna,.. somethings wrong with my rabbit ears. Edna dammit call the station and tell them the signal went haywire."
"I don't have a computer or any of those fancy gizmos".
Hey, we need an old lady smiley!
PostPosted: Thu Feb 19, 2009 9:19 am
Wilrobnson- Now happier than ever that he doesn't watch TV!
PostPosted: Thu Feb 19, 2009 10:18 am
Which brings me to ask, where did the term "you've been Rick Roll'd" originate?
PostPosted: Thu Feb 19, 2009 10:59 am
http://preview.tinyurl.com/d2oqay
PostPosted: Thu Feb 19, 2009 8:58 pm
http://en.wikipedia.org/wiki/Rickrolling
