It is currently Sat Sep 19, 2026 6:40 pm
PostPosted: Tue Apr 28, 2020 8:42 pm
Looking for one that has at least 2 leads for LTE, 1 for WiFi and the 1 for the GPS. The higher gain, the better.
Application- center punch roof mount to the in-car Cradlepoint. Looking for WiFi coverage up to about a 200' radius around the car. The stock Cradlepoint antennas are great in-car and locally, but I sometimes go further afield. Also, better gain on LTE (AT&T) would be a good thing.
PostPosted: Wed Apr 29, 2020 12:54 am
https://www.sierrawireless.com/products-and-solutions/routers-gateways/airlink-antennas/
PostPosted: Wed Apr 29, 2020 9:53 am
I do not believe any of the connectors are reverse polarity on a Cradlepoint so watch out for that.. The ones we install are all SMA.
What is the model number of your Cradlepoint?
https://www.tessco.com/product/lte-mimo ... ant-550990
PostPosted: Wed Apr 29, 2020 6:20 pm
Took the Sierra Wireless 4/1 sharkfin.
Thanks
PostPosted: Wed Apr 29, 2020 6:58 pm
That one has reverse polarity connectors on the WIFI connections.. You will need to get them changed.
Unless by chance that Cradlepoint has changed to RP connections on their WIFI antenna connectors..
PostPosted: Wed Apr 29, 2020 7:40 pm
I'll look at it when it gets here next week.
PostPosted: Thu Apr 30, 2020 3:26 am
The one he ordered should work fine -- the Cradlepoint uses RSMA for its wifi connection.
A better-spec option: https://www.digikey.com/product-detail/ ... ND/6602463
https://media.digikey.com/pdf/Data%20Sh ... 9273CE.pdf
You also get a 430-520 UHF PL-259 connection for extra fun! (e.g. you add a rubber duck of your choosing)
PostPosted: Thu Apr 30, 2020 8:33 am
Shirley you jest? Yeah yeah.. "don't call me Shirley"! I know. (surely for Tim before he corrects my spelling)
Every one of these units Ive installed have been all SMA on every antenna.
PostPosted: Thu Apr 30, 2020 12:11 pm
The datasheet for Wil's model says the w-ifi port is RSMA -- but since there are 57 versions of Wil's model -- he'll have to confirm... which model he has exactly...
The LTE Main/Aux are SMA as is the GPS. The Wi-Fi is RSMA per the datasheet.
PostPosted: Thu Apr 30, 2020 3:12 pm
I thought you were speaking of the Cradlepoint. Lack of coffee.
PostPosted: Thu Apr 30, 2020 3:16 pm
...um, I was...
PostPosted: Thu Apr 30, 2020 4:25 pm
Screw it Im going back to bed.. I still blame no coffee today.
Ive put in dozens of these into buses and seriously do not remember them having reverse polarity SMA connectors on them. Ill have one of these in hand to install for a customer tomorrow. https://cradlepoint.com/sites/default/f ... 0119-b.pdf shows I need my eyes checked I suppose.
