It is currently Tue Aug 04, 2026 9:57 pm
PostPosted: Sun Jan 01, 2017 7:25 pm
Installed in a 1980 Ford F150 2wd long bed pickup... uses the broadcast antenna. Squelch not functioning correctly in the scanner... Truck needs some work also but moves under its own power and will stop when you hit the brakes... Motorola mount installed in the center of the cab roof, RG58 coax terminated in PL259, ready for the radio of your choice and antenna.
PM or reply here if interested, or use the usual voice orderwire 2M FM frequency for inquries...
Eric
KB7DQH
PostPosted: Sun Jan 01, 2017 8:12 pm
kb7dqh wrote:
...uses the broadcast antenna. Squelch not functioning correctly in the scanner.
Wow...I think I had one of those in a patrol rig in 199x...Stupid no PL function and always had the alternator dentist's drill whine.
Orderwire was UHF, and encrypted.
PostPosted: Wed Mar 08, 2017 10:26 pm
Uninstalled from the vehicle along with the magic gizmo which permits connection via the broadcast receiver antenna. Rumor has it the vehicle is still functioning but is no longer in my possession...
