It is currently Thu Sep 24, 2026 10:05 am
PostPosted: Fri Feb 28, 2014 5:10 pm
I have for sale one used Motorola MCS2000 900MHz Model I mobile radio, model # M01WJL4PW4CN, flashcode 000002-000000-8. This is a 48 channel, 30 watt radio with bandsplit of 896-941MHz. The radio is currently programmed for a couple of local 33cm ham repeaters and is in excellent condition. Package will include palm mic, full length power cord, mounting bracket, accessory connector and aftermarket programming cable. I currently do not have the ability to program this for the ham bands. SOLD
1 used HMN1050C OEM desk microphone for the Astro Spectra/Spectra/XTL(W series heads)/Maratrac(A7 head) radios. Mic is in good condition with some sings of use. SOLD
1 used RLN4008E OEM RIB with RIB to PC cable and original paperwork. RIB is in excellent condition and does work but ON/OFF toggle switch has intermittent short. SOLD
1 used WPLN4114AR OEM V3.40 Impres Adaptive single unit charger with power cord and user guide. Charger is in excellent condition was used very little. SOLD
1 Otto Communications V2-D2MA111 Lightsword Speaker Mic for the HT/JT1000/MT/MTS2000/MTX/XTS series radios. Mic is in excellent condition and was never used in the field. It has an earphone jack and features two white LEDs that can be switched on for reading documents. SOLD
XTS1500 Model I VHF
48 channel
Bandsplit: 136-174MHz
Model: H66KDC9PW5AN
Flashcode: 100001-000000-7
Firmware: R09.00.41
DSP: R16.00.01
Serial: 687TEN****
Radio is in very good shape, the housing has some minor signs of use but nothing major and has all matching tags. Last programmed with CPS R19.01.00. Will come with whip antenna, speaker mic clip retainer, 1 new NTN7209A single-unit charger, 1 Impres battery. Free basic programming is available. SOLD
XTS3000 Model III UHF
255 Channel
Bandsplit: 403-470MHz
Model: H09RDH9PW7BN
Firmware: 07.71.07
DSP: N08.02.08
Serial: 620AAW****
Secure: KG1 DES-OFB
KG2 DES-XL
KG3 None
Radio is in very good shape, the housing has some minor signs of use but nothing major, no dead pixels on display and has all matching tags. Last programmed with CPS R05.03.00. Will come with whip antenna, 2 belt clips, 1 WPLN4114AR single-unit Impress charger, 1 Impres battery and 1 non-Impres battery. Free basic programming is available. SOLD
XTS3000 Model III VHF
255 Channel
Model: H09KDH9PW7BN
Firmware: 07.71.07
DSP: N08.03.05
Serial: 620AAW****
Secure: KG1 DES-OFB
KG2 DES-XL
KG3 AES-256
PostPosted: Sun Apr 13, 2014 11:48 am
All are sold....
