It is currently Mon Aug 17, 2026 8:41 am
PostPosted: Tue Mar 06, 2012 8:24 pm
Yaesu VX-8R...
Have box, and even the Yaesu sticker (heh)
Hi-cap Batt
Standard cap Batt
high rate charger
standard rate charger (yes, 2 chargers)
Charging stand (charge battery attached to, or separate from, radio)
Bluetooth module installed
Spkr. mic.
Surveillance earpiece. (2 wire, one to ear, PTT to lapel/wrist)
Diamond SRH-519 antenna (better than stock)
Programming cable + software
Will grab pics later..
Looking for $400....
The spkr/mic and surveillance kit are like new.
Both batteries hold really good charges...
Bluetooth module works great, allows you to QSO/monitor without having anything physically connected.
And of course, you know it has APRS built in.......
Quad band, 6/2/220/440 & 1W AM tx on 6m.
NEVER MODIFIED. No mars/cap or anything like that, only been used on amateur frequencies, and sparingly at that...
I don't use it as much as I thought I would, and wanna move on to something a little simpler.
I'll post pics a bit later....
Put it on an analyzer for grins and giggles about a month ago, had about 5 1/4 watts out on high......with good rx sensitivity..
two.4.zero - four. 4 . one - six. 4 .two. 2
PostPosted: Sat Apr 07, 2012 3:04 am
Here are the pics. I do not have the second charger or the software pictured.
Any questions?
