It is currently Fri Sep 18, 2026 6:50 pm
 Post subject: a little mapping project
PostPosted: Sun Oct 11, 2015 8:16 am
Soo a little while ago I started a little quest to Map out some of the long lines based on a few old posts MikeGilbert’s photos talking about Raven’s roost, and a few other pics.
http://www.interceptradio.com/bbs/search.php?keywords=long+lines&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
So I started with http://long-lines.net/places-routes/ and I was just eyeballing what I knew of my area and went out from there. Digging around I found another decent site http://www.badpixels.com/jm3000/sites/AT/index.html the CSV data file proved to be helpful, and then http://n3tuq.com/longlines/ which I’m pretty sure got the info from the previous link It helped a lot.
Interesting enough I found that http://www.skyvector.com helped a bit with the VFR sectionals. (a handy site to have as well)
Anyways I’ve got a fair amount of WA, OR, ID, MT and starting WY. Some of the sites may not show on the most current Ortho Photos on Google Earth, thankfully some of the older Ortho’s show what is now gone or confirmed a building or tower foot print.
Hope you enjoy and let me know what you think, If you have feedback or want to contribute that would be helpful as well.
PostPosted: Sun Oct 11, 2015 9:01 am
I have about a dozen pictures inside and out of the Bethel Ridge site. Where should I submit them?
PostPosted: Sun Oct 11, 2015 11:53 am
Create a Bethel Ridge topic here and upload them or create a Bethel Ridge page on the wiki. One nice thing about using the forums vs. the wiki is that its easier for people to add comments/discussion on the forums.
PostPosted: Mon Oct 26, 2015 3:40 pm
Updated File. Is this still worth doing? WY, UT and NV (not 100% yet still in progress) Found a few "passive repeaters" Big walls in the woods that might be of interest.
AT&T microwave.kmz [82.97 KiB]
Downloaded 388 times
PostPosted: Wed Nov 04, 2015 4:33 pm
Definitely worth doing. I've got pictures of some WYO sites.
-Tom, W1WSO -- Plymouth, CT
http://tf.sdf.org/monitor/
PostPosted: Tue Jan 05, 2016 2:27 pm
Here are a few more states that I've had time to work on, they are individual state and Path files
File comment: Paths ND
Paths ND.kmz [3.55 KiB]
Downloaded 374 times
File comment: North Dakota sites
ND.kmz [3.9 KiB]
Downloaded 385 times
PostPosted: Tue Jan 05, 2016 2:29 pm
a few more for your enjoyment. I had a big hiccup with storing the last files and will get back to a larger master file eventually It's just going to take some time.
File comment: Paths MN
Paths MN.kmz [3.25 KiB]
Downloaded 348 times
File comment: MN Sites
MN.kmz [4.08 KiB]
Downloaded 345 times
PostPosted: Tue Jan 05, 2016 2:31 pm
and the last for now... enjoy
File comment: Paths WI
Paths WI.kmz [4.27 KiB]
Downloaded 365 times
File comment: wi sites
WI.kmz [4.91 KiB]
Downloaded 378 times
PostPosted: Wed Jan 27, 2016 4:23 pm
I've been trying to find the last little bits of MI and have been a little busy and also kinda hitting dead ends. If you have time take a look for a few of the sites that still remain.
http://long-lines.net/places-routes/maps/Detroit_MI-0170.html
http://long-lines.net/places-routes/maps/MW6610-C.jpg
This one has a mix of the old AT&T trunk for the lack of a better term, and some MI Bell sites added.
Paths MI.kmz [7.37 KiB]
Downloaded 362 times
MI.kmz [7.46 KiB]
Downloaded 329 times
PostPosted: Mon Feb 01, 2016 12:28 am
Pimp Daddy Radio
Awesome project! The n3tuq site helped fill in a few missing links. For some reason, Texas has disappeared from the map.
I did most of the West coast on this map. You can download data if you log into google.
https://www.google.com/maps/d/viewer?mid=z5NtUMEoVhTw.kdRHyoyqygI8
PostPosted: Mon Feb 01, 2016 4:19 pm
updated the file, addition work in NE Montana and a few other spots. Some speculations in a few other areas.
AT&T microwave.kmz [92.84 KiB]
Downloaded 350 times
