It is currently Tue Sep 22, 2026 12:11 am
PostPosted: Tue May 05, 2020 1:30 pm
I would like to add a VHF air audio feed for Lake Havasu City Municipal Airport (KHII). It's a general aviation airport as well as a refueling station for military aircraft. There's always a lot going on in the airspace above the city. Can someone point me in the right direction for my request?
Thanks,
Jason Castellucci
PostPosted: Thu May 07, 2020 7:55 pm
No problem I can help with that.
Do you have something to encode/stream the audio from ?
PostPosted: Sat May 16, 2020 12:41 pm
Sorry for the delay in my response. I have a Bearcat 125AT scanner as my audio source, connected to a 1/2 wave dipole indoor antenna.
PostPosted: Sat May 16, 2020 8:01 pm
Do you have a computer or device (like a Raspberry Pi) that can be dedicated to encoding the audio ?
PostPosted: Sat May 16, 2020 8:20 pm
Yes, my desktop computer can be used for that purpose. I have audio Y cables from Radio Shack.
PostPosted: Tue Jun 16, 2020 11:19 pm
I have everything set up and just need to get the settings for the streaming software.
PostPosted: Wed Jun 17, 2020 6:07 am
Which encoder are you using ?
PostPosted: Wed Jun 17, 2020 9:25 pm
My desktop computer can encode the audio. I have a feed set up on toolshed: https://www.toolshed.com/listen/feed/32737. Can I still provide a stream for your database using the same sound card?
PostPosted: Wed Jun 17, 2020 9:43 pm
Correction--feed is on toolshed: https://www.toolshed.com/listen/feed/32737
PostPosted: Wed Jun 17, 2020 9:44 pm
toolshed-->toolshed
PostPosted: Wed Jun 17, 2020 9:45 pm
I'm guessing you're not a fan?
PostPosted: Thu Jun 18, 2020 6:33 am
What streaming software are you using ?
PostPosted: Thu Jun 18, 2020 10:22 am
BUTT
PostPosted: Thu Jun 18, 2020 10:25 am
Correction--I'm now using ScannerCast.
Users browsing this forum: No registered users and 18 guests
