It is currently Mon Sep 21, 2026 9:34 am
 Post subject: 127.05 Mhz
PostPosted: Fri Nov 15, 2019 5:09 pm
Anyone know who this is exactly? Here's the latest ARTCC frequencies and it's not mentioned but it's highly active. The controller says "Seattle Center" but no official listing of this frequency..?
https://zseartcc.org/documents/view/110
 Post subject: Re: 127.05 Mhz
PostPosted: Fri Nov 15, 2019 8:34 pm
127.05 is a Low/High altitude control freq for sector 31 at the Beacon Hill and Ft. Lawton RCAG. And yes I was too lazy to put it in the Intercept database where it should be. zseartcc.org is a simulator site so perhaps they aren't 100% in line with reality. If you have the time (like a lot of it), ATC sectors can usually be figured out by listening to the handoffs however it gets a little dicey when they merge sectors and simulcast.
Edit: 127.05 is also at the Badger Mt. RCAG which makes sense as sector 31 covers both sides of the mountains:
https://zseartcc.org/public/images/maps/ZSEHIGH.png
Yes I quoted a simulator site but in this case they called it a "Real World" sector map. Note that more freqs are in play than the basic ones they list.
